multiphaseEulerFoam with RAS only wroks with mixtureKEpsilon |
July 3, 2021, 16:32 |
Gustavo
Rep Power: 4 |
I am trying to run the damBreak case with two fases (air and water) with multiphaseEulerFoam. When I use the mixtureKEpsilon model works ok, but if I use the kEpsilon or kOmegaSST dont run, stops in the first cycle. Someone can help? The case is attached. Other question is about diameter of the phases. The results seens very sensible to this parameters, the fluid with high values (1e-4) of diameter seens more viscous. Anyone has a good documentation about this? I cant found a good one. Thanks. |
Error in LRR (RAS) model in OpenFOAM v4.1 | Inquisitor101 | OpenFOAM | 4 | November 29, 2023 14:11 |
DamBreak case multiphaseEulerFoam with RAS | gustavoliveira | OpenFOAM Running, Solving & CFD | 2 | December 3, 2021 19:14 |
Error running RAS kEpsilon | quarkz | OpenFOAM Running, Solving & CFD | 1 | December 31, 2018 03:10 |
Using RAS turbulence modelling in multiphaseEulerFoam (OF 2.1.1) | anuragm | OpenFOAM Running, Solving & CFD | 0 | November 26, 2014 09:45 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
