December 31, 2016, 14:43 |
rhoCentralFoam solver instability
Mike
Rep Power: 9 |
I'm trying to setup a canonical supersonic cavity-in-duct flow simulation (2D for now) using rhoCentralFoam, but am having stability issues with the solvers when using anything but extremely small timesteps (CFL < 0.3). When using larger timesteps I get oscillations emanating from the top and bottom walls at the inlet on startup which eventually produce a floating point exception. I'm pretty new to openfoam and cfd in general, so I'm not sure if the issue is with my numerical schemes, my boundary conditions, or if I need to initialize better. Any suggestions are greatly appreciated!
My setup is: BCs: U - fixedValue at inlet, noSlip on walls, zeroGradient on outlet p - zeroGradient at inlet and walls, waveTransmissive on outlet T - fixedValue at inlet, zeroGradient on walls and outlet k - fixedValue on inlet and walls, inletOutlet at outlet alphat & nut - zeroGradient everywhere Initialization: Quiescent everywhere Solvers: Code:
{ "(rho|rhoU|rhoE)" { solver diagonal; } "(k|nut)" { solver PBiCGStab; preconditioner DILU; nSweeps 2; tolerance 1e-10; relTol 0; } U { solver PCG; preconditioner FDIC; tolerance 1e-10; relTol 0; } e { $U; tolerance 1e-10; relTol 0; } } Code:
fluxScheme Kurganov; ddtSchemes { default CrankNicolson 0.9; } gradSchemes { default cellLimited Gauss linear 1; } divSchemes { default none; div(tauMC) Gauss linear; div(phi,k) Gauss limitedLinear 1; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; reconstruct(rho) vanLeer; reconstruct(U) vanLeerV; reconstruct(T) vanLeer; } snGradSchemes { default corrected; } |
January 4, 2017, 21:25 |
Mike
Rep Power: 9 |
wait, is this paper correct? -> https://www.researchgate.net/publica...rk_of_OpenFOAM
is rhoCentralFoam actually an explicit solver, even though I'm using an implicit time-stepping scheme? If so, why am I having to invert matrices? |
February 24, 2017, 02:01 |
Di Cheng
Hi, MikeC
I encountered the same problem. I am also very confused. I just tested the forwardStep example in OpenFOAM 201612+. It is true that CFL no. matters for this "implicit solver". I tested CFL=0.2, 0.3, 0.4 and 0.5, the oscillations behind shock becomes larger for larger CFL, and it goes to error at CFL = 0.5. I am looking into the source code. |
February 25, 2017, 14:09 |
Mike
Rep Power: 9 |
Hi Chengdi,
I looked into it a little more, and if I'm understanding it correctly part of the system is being discretized explicitly (rhoe, rhoU, etc) and part implicitly (p, etc). The difference is in fvc versus fvm. I've been told that this method allows you to use a larger CFL than you could if you were using a purely explicit solver. Still not sure why the default isn't just a completely implicit solver. |
March 10, 2017, 23:15 |
Di Cheng
Yes, I have found the paper "Implementation of semi-discrete, non-staggered central schemes in a colocated, polyhedral, finite volume framework, for high-speed viscous flows".
Because OpenFOAM is a segregate solver which solve variables in cell volume center separately. So you can choose to solve one variable implicitly and other variables explicitly. For rhoCentralFoam, it construct the KT or KNP numerical flux explicitly. So it must be bounded by CFL number like explicit scheme. |
July 9, 2021, 10:58 |
Implicit solver vs explicit solver
Jnana Bhaskar Rao
Rep Power: 6 |
I am replying on this old thread because I have struggled with similar questions. I believe a completely implicit solver will require a U, p and e to be strongly coupled. This would require an iterative semi-explicit method solver like SIMPLE. Usually the intermediate states of such solvers are not very stable. If you read Issa's pioneer paper on PISO (from 1985 or 1986), one of his motivations for the algorithm was to allow for large time steps. This is not stable for explicit solvers as they do not have any weights for the t+1 time steps and can be erroneous when the time variations are high. However, it is possible to avoid the errors of incorrect temperature at the cost of higher computation by increasing the outer corrector loops in rhoPimpleFoam and sonicFoam as they are based on combined PISO and SIMPLE (PIMPLE). In rhoCentralFoam, the only ways to increase stability are reducing the Courant number, using more stable (dissipative) schemes or better initialization, as far as I am aware.
rhocentralfoam |
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 05:26 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
