how to check when the residual is smaller than the prescribed tolerance while solving
Dear,
I have set the tolerance for U and p separately, and how can I realize automatically that the simulation will stop once the residuals for both U and p are smaller than the corresponding predefined tolerance? Thank you for any help. Best Regards, Bill |
Bill,
I don't know which solver your are using, but consider the SIMPLE for example. Look at the source code of Foam::simpleControl::criteriaSatisfied(). I understand from it that the convergence is achieved just when the residuals of all fields are less then the values that were set for each one. That is, it is doing already what you wanted it to do. Best regards, Thomas |
steady flow
1 Attachment(s)
Thanks for the answer. I compiled a new solver, a similar one to icoFoam. I agree with you that the solution is converged if the residuals are less than the prescribed tolerances. I am confused while I am reading one paper, " From steady to unsteady laminar flow in model porous structures: an investigation of the first Hopf bifurcation", the part talking about the residual and the tolerance is attached. Because it seems that the author used the relation between them to judge whether the flow is steady or not at a certain Re. I am confused whether the criteria for the convergence could be used to determine the flow is steady or not. Thank you. Best Regards, Bill |
tolerance and convergence in fvSolution
1 Attachment(s)
I have set the tolerance for p and U separately in fvSolution file, as shown below. Code:
solvers The related part about the convergence in the post is also screenshotted and attached. I want to set the convergence separately for p and U. How can I realize this in the fvSolution file? I just add the convergence in the PISO content? If so, how can I add different values for p and U? Thank you in advance. Best Regards, Bill |
Dear Bill
Please correct me If I haven't understood correctly but what you are trying to do is setting residuals controls separately for pressure and velocity. You can do this by simply including the following code in the fvSolution file Code:
PISO Kind regards! |
Thank you for your reply. Yes! This is the first step I want to do. (To stop the simulation as long as the residuals are smaller than the tolerance.) Code:
PISO I am wondering about the second step if it is possible to check the flow is steady according to the convergence criteria. Thank you. Best Regards, Bill |
Dear Bill
I've been using residualControls with SIMPLE algorithm which is for steady-state simulations. Probably there must be a problem with this function when turning to transient solvers like PISO. Maybe a more experienced user can tell us why this happens. Could you please post the error message that was produced when you tried it, just to gain further insight in OF functionality ? Which OF version are you using? Regarding your second question, the author states that since the user prescribes the tolerances, is up to the user to set the threshold of the, lets say, "steadiness" of the flow. So in our case, we state that when pressure residual reaches below 1e-5 and velocity residual reaches below 1e-3, the simulation has converged. The tolerances here are the 1e-5 and the 1e-3. However, I think that wether a flow is steady or unsteady has nothing to do with that. I found this article explaining steady and unsteady flow. I hope I helped :) Please correct me if I am wrong! Kind regards |
error while using the residualControl
1 Attachment(s)
Dear jeytsav,
The error while I am using the residualControl is like bellow. Code:
/*---------------------------------------------------------------------------*\ Thank you for the article. It is very kind of you to help me. I have read through the website, but did not find a clue on how to determine at which Re the flow will lose stability while using the transient solver. The unsteadiness is related to the vortex shedding / oscillating streamlines, it is easy to observe these phenomena in a simple situation, like flow past a cylinder, at the same time, the lift coefficient or the component of velocity may be monitored to check the oscillating values with time, as attached, and also a related spectral analysis may be done. Q2: But can these indications be just used to determine if the flow is steady or used only as auxiliaries? I am confused and need help on this. Thank you. Best Regards, Bill |
simulations will not stop using convergence
Dear jeytsav,
I added the lines in fvSolution, using Code:
convergence Code:
Time = 20000.0000000443724 Thank you. Best Regards, Bill |
Dear Bill
Regarding the residual control I have found this thread that might solve the problem. Check the last post (post #7). My approach to the problem would be to first solve as a steady-state case and then check whether the results agree (i.e. no oscillations) and if not, switch to a transient solver to have a better capture. I think that the oscillation of force coefficients is a clear indication of unsteady flow as the field changes around the body with time. Actually I am not sure whether is correct to use the word "time" when talking about steady-state because it is time-independent. Maybe the word "pseudotime" is better. Also note, that a flow might be unsteady in the beginning (so you will have oscillations) but then oscillations could be damped indicating a steady flow. Kind regards |
results checked
Dear jeytsav,
Thank you very much for your quick help. I have checked the results of the transient simulations. There is no oscillating streamlines, the same as for the steady solution. In addition, I have monitored the component of velocity, and there is no peridic oscillation. Also, I have transformed the velocity component using FFT, and found there is only a signal at f=0. Based on the above analysis, I assumed that the flow is still at steady for the Re range I have tested. BTW: I have modified the fvSolution file according to the thread you recommended. I am testing and will post the results here. It is really very kidn of you to help me so much. Thank you. Best Wishes, Bill |
Regarding your problem with the residual control: Which solver are you using? A solver based on PISO or on PIMPLE? If your solver is based on PIMPLE (e. g. pimpleFoam) you have to add something like the following to the PIMPLE section within system/fvSolution
PIMPLE |
Thanks for your reply and the detailed information. I am using icoFoam, based on PISO. But I would like to modify the fvSolution file according to your suggestions. Code:
PISO I have posted the problem here and wonder if you have experience in running parallel. https://www.cfd-online.com/Forums/op...ning-most.html Thank you in advance. Best Regards, Bill |
Are you sure, that you need such tight tolerance levels? Normal values seems to be in the range of 1e-4.
And these values are the same ones for the solver as in post #4. Thanks. Regards, Bill |
residualControl not work
1 Attachment(s)
Dear,
To update, I have run the case with the residualControl mentioned above, but it seems that it does not work al all. The simulation only ends according to the endTime in the controlDict file. Thank you in advance for any suggestions. Best Regards, Bill |
Your solver solves for the fields Ux and Uy, so these names must appear in the PISO section of fvSolution. Otherwise these two fields are not checked, if they have converged. Please use the code from my first comment: https://www.cfd-online.com/Forums/op...tml#post633783
residualControl still not work
Dear jeytsav,
I have modified the fvSolution file according to your suggestions. But it still does not work. The simulation only ends at the endTime, the residualControl function still does not work. The fvSolution file is like this: Code:
FoamFile I have no clue to do what for the next step... Yours sincerely, Bill |
residualControl for pimpleFoam
Dear,
I have found an example, which uses the residualControl for pimple: https://openfoamwiki.net/index.php/O...hm_in_OpenFOAM And below is what I got from the openFoam support: icoFoam is a simple demonstration solvers and does not and need not support residual control, fvOptions etc. If you are developing an transient incompressible laminar or turbulent flow cases choose either pisoFoam or pimpleFoam if you need residual control, fvOptions etc. Does this mean that the residualControl does not work for PISO algorithm? Thank you. I am simulating the transient, laminar, incompressible flow. Regards, Bill |
For residualControl to work nOuterCorrectors should be greater than 1. Since pisoFoam does not have outer correct loop (or in other words nOuterCorrectors is always 1), it does not check for convergence in term of initial residuals; pimpleFoam does. |
