segmentatio fault using cyclic boundary conditions in FOAM extend 3.2 |
October 28, 2016, 06:40 |
Rep Power: 9 |
Hi everybody,
I have a very simple hexahedral fluid domain formed by an inlet, an outlet and four side walls. An object is included in this domain and my intention is to study the flow through this object using the Immersed Boundary Method. Up to now everything works fine but, instead of having four solid side walls, I would like to set the patch type to cyclic (for the side walls) in order to simulate a periodic boundary. I set the blockMeshDict as follows Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } convertToMeters 1; vertices ( (-112 0 0) (336 0 0) (336 56 0) (-112 56 0) (-112 0 28) (336 0 28) (336 56 28) (-112 56 28) ); blocks ( hex (0 1 2 3 4 5 6 7) (448 56 28) simpleGrading (1 1 1) ); boundary ( in { type patch; faces ((0 4 7 3)); } out { type patch; faces ((2 6 5 1)); } lato1 { type cyclic; neighbourPatch lato2; faces ((0 1 2 3)); matchTolerance 0.01; } lato2 { type cyclic; neighbourPatch lato1; faces ((4 5 6 7)); matchTolerance 0.01; } lato3 { type cyclic; neighbourPatch lato4; faces ((0 4 5 1)); matchTolerance 0.01; } lato4 { type cyclic; neighbourPatch lato3; faces ((3 7 6 2)); matchTolerance 0.01; } ); Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 3.2-5ab3390aef43 Exec : blockMesh Date : Oct 28 2016 Time : 12:19:16 Host : JM's_NB PID : 4946 CtrlDict : "/home/amedeo/Scrivania/Documenti/ibNew/system/controlDict" Case : /home/amedeo/Scrivania/Documenti/ibNew nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/amedeo/Scrivania/Documenti/ibNew/constant/polyMesh/blockMeshDict" No non-linear edges defined Creating topology blocks Creating topology patches Creating block mesh topology Segmentation fault (core dumped) I also tried to set the blockMeshDict with only patches without any specification on the nature of the boundaries and then setting the cyclic patches in the boundary file; in this case blockMesh works (obviously...) but i get the same message error (segmentation fault) in the solver log (i.e. potentialIBFoam). I really don't understand what's wrong because the error message is too generic but maybe I'm doing some trivial mistake. |
January 16, 2017, 07:05 |
Milad Setareh
Rep Power: 13 |
Hi
I have the same problem, any response???? |
January 18, 2017, 05:27 |
Rep Power: 9 |
this should work: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } convertToMeters 1; vertices ( (-112 0 0) (336 0 0) (336 56 0) (-112 56 0) (-112 0 28) (336 0 28) (336 56 28) (-112 56 28) ); blocks ( hex (0 1 2 3 4 5 6 7) (448 56 28) simpleGrading (1 1 1) ); boundary ( in { type patch; faces ((0 4 7 3)); } out { type patch; faces ((2 6 5 1)); } sxdx { type cyclic; faces ((0 3 2 1) (4 5 6 7)); } topbottom { type cyclic; faces ((1 5 4 0) (3 7 6 2)); } ); |
cyclic boundaries, foam extend 3.2, immersed boundary method |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
