pimpleFoam - Flow across an oscillating cylinder simulation crashing
Old   August 31, 2019, 16:42
Default pimpleFoam - Flow across an oscillating cylinder simulation crashing
Kimster
iceman53y is on a distinguished road
I am an openFoam newbie. So please be kind.
I am trying to determine the lift and drag coefficients of an oscillating cylinder located inside a bundle of static cylinders.
This what I have done so far:
1. I have created a geometry and mesh through GMSH and exported to OpenFoam using gmshToFoam. My meshing strategy was to have a structured mesh close to the cylinders that I want to monitor and the rest of the domain has an unstructured mesh.
2. I used a pointDisplacement method to oscillate the cylinder that I wanted to oscillate. I used the displacementLaplacian solver for my dynamicmeshDict.
3. Setup my boundary conditions, in the U and P files. (shared at the bottom of the post)
4. I setup my fvSolution and fvschemes files using a tutorial I found online for an oscillating object. I donot fully understand these files and I feel the problem lies here.
My simulation seems to run fine for some time. The time depends on the size of the mesh and the frequency of the oscillating cylinder. The finer the mesh , the smaller the time the simulation is able to run. The courant number starts to increase gradually, till it explodes or the timestep size decreases to very very low values that the simulation gets stuck. My drag coefficients start to increase exponentially as well when the courant number increases.
I have tried to increase the mesh size, decrease the frequency and amplitude of the oscillating cylinder. I get results that are ok for some time then eventually the courant number starts to increase.
My folder files are larger than the limit of this forum. So I'm sharing a downloadable link below, Additionally at the end of this post I have copied some of my files files.
https://drive.google.com/file/d/1U7m...ew?usp=sharing
Appreciate if someone can take a look and let me know what I am doing wrong.
Oh yes, I am using the pimplefoam solver for this application.
This is what my polyMesh boundary file and the U, P and pointDisplacement files look like.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
12
Frontandback
type empty;
physicalType empty;
inGroups 1(empty);
nFaces 31380;
startFace 25646;
Tube_NW
type patch;
physicalType patch;
nFaces 56;
startFace 57026;
Tube_W
type patch;
physicalType patch;
nFaces 56;
startFace 57082;
Tube_NE
type patch;
physicalType patch;
nFaces 56;
startFace 57138;
Tube_C
type patch;
physicalType patch;
nFaces 56;
startFace 57194;
Tube_SW
type patch;
physicalType patch;
nFaces 56;
startFace 57250;
Tube_E
type patch;
physicalType patch;
nFaces 56;
startFace 57306;
Tube_SE
type patch;
physicalType patch;
nFaces 56;
startFace 57362;
Wall
type patch;
physicalType patch;
nFaces 300;
startFace 57418;
Outlet
type zeroGradient;
physicalType zeroGradient;
inGroups 1(zeroGradient);
nFaces 23;
startFace 57718;
Inlet
type patch;
physicalType patch;
nFaces 23;
startFace 57741;
Remaining_tubes
type patch;
physicalType patch;
nFaces 528;
startFace 57764;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (2 0 0);
boundaryField
Frontandback
type empty;
Tube_NW
type fixedValue;
value uniform (0 0 0);
Tube_W
type fixedValue;
Tube_NE
type fixedValue;
Tube_C
type movingWallVelocity;
Tube_SW
type fixedValue;
Tube_E
type fixedValue;
Tube_SE
type fixedValue;
Wall
type fixedValue;
Outlet
type zeroGradient;
Inlet
type fixedValue;
value uniform (0.1 0 0);
Remaining_tubes
type fixedValue;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
Frontandback
type empty;
Tube_NW
type zeroGradient;
Tube_W
type zeroGradient;
Tube_NE
type zeroGradient;
Tube_C
type zeroGradient;
Tube_SW
type zeroGradient;
Tube_E
type zeroGradient;
Tube_SE
type zeroGradient;
Wall
type zeroGradient;
Outlet
type fixedValue;
value uniform 0;
Inlet
type zeroGradient;
Remaining_tubes
type zeroGradient;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class pointVectorField;
location "0";
object pointDisplacement;
dimensions [0 1 0 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
Frontandback
type empty;
Tube_NW
type uniformFixedValue;
uniformValue constant (0 0 0);
Tube_W
Tube_NE
Tube_C
type oscillatingDisplacement;
omega 69.934;
amplitude ( 0.002 0 0 );
value uniform ( 0 0 0 );
Tube_SW
Tube_E
Tube_SE
Wall
Outlet
type zeroGradient;
Inlet
Remaining_tubes
Following is my dynamicMeshDict
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object dynamicMeshDict;
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solver displacementLaplacian;
displacementLaplacianCoeffs
diffusivity inverseDistance 1(Tube_C);
//Trying to oscillate Tube_C here
Following is the fvSolution file.
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
pcorrFinal
solver GAMG;
tolerance 0.02;
relTol 0;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration no;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
p
solver GAMG;
tolerance 0;
relTol 0.01;
nPreSweeps 0;
nPostSweeps 2;
mergeLevels 1;
pFinal
$p;
tolerance 1e-06;
relTol 0;
U
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-05;
relTol 0.1;
UFinal
$U;
tolerance 1e-05;
relTol 0;
cellMotionUx
solver PCG;
preconditioner DIC;
tolerance 1e-08;
relTol 0;
cellMotionUxFinal
solver PCG;
preconditioner DIC;
tolerance 1e-08;
relTol 0;
"cellDisplacement.*"
solver GAMG;
tolerance 1e-5;
relTol 0;
cacheAgglomeration true;
mergeLevels 1;
PIMPLE
correctPhi yes;
nOuterCorrectors 2;
nCorrectors 1;
nNonOrthogonalCorrectors 0;
pRefCell 1001;
pRefValue 0;
relaxationFactors
fields
equations
"U.*" 1;
Thank you.
iceman53y is offline   Reply With Quote
Old   September 5, 2019, 22:42
Kimster
Fixed it.
Embarrassing error
Old   November 27, 2019, 05:13
Daniel Duque
dduque is on a distinguished road
So, what was the error ??
dduque is offline   Reply With Quote
Drag force coefficient too low for a flow past cylinder at Re= 1e05 Scabbard STAR-CCM+ 2 June 5, 2020 14:44
Drag Coefficient calculation for flow over a 2D Cylinder at High Reynodls Numbers DanielBarreiro CFX 13 February 26, 2019 09:40
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 05:49
Simulation of the Flow past a circular cylinder using STAR-CD M. S. GUEROUACHE Main CFD Forum 0 October 1, 1998 10:51
