January 20, 2017, 05:53 |
Simulation of a multi-species problem
Samuele Z
Rep Power: 18 |
Dear All,
I am writing to ask you a general question about OpenFOAM solvers. I have a X-shaped channel: from inlet-1 air enters; from inlet-2 a different gas mixtures enters. I am sure I do not have any chemical reaction. What I would like to study is the species-transport and - above all - the concentration (and distribution) of O_2 on the outlets. Do you have any suggestion? Which is the right solver? Do you know if there is a tutorial solved? |
January 23, 2017, 03:48 |
Hi, you can use reactingFoam with the reactions turned off for species mixing.
Just follow one of the original tutorials and get it to run without reacting. Tom |
January 23, 2017, 05:48 |
Samuele Z
Rep Power: 18 |
That's great.
Thanks a lot Tom. I am gonna investigate this solver. Thanks a lot, Samuele |
January 26, 2017, 07:29 |
Samuele Z
Rep Power: 18 |
Hey Tom,
I was thinking.. ..does this solution work with liquids, also? Thanks a lot, Samuele |
January 26, 2017, 08:13 |
Probably not, liquid-liquid mixing is different from gas-gas mixing. It depends on the solubility of the liquids. Think about oil in water or alcohol in water. I guess you need either interFoam or twoLiquidMixingFoam or maybe interMixingFoam, or perhaps even twoPhaseEulerFoam. Regards, Tom |
Loosing Volume, High Simulation Time and Problem About stl File | thetitans | FLOW-3D | 3 | December 1, 2016 06:36 |
Multi Species Problem (mass fraction) | usamaperwez | CFX | 0 | July 27, 2016 07:07 |
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. | Ari | Fluent UDF and Scheme Programming | 4 | May 31, 2016 08:51 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
non-physical turbulence viscosity in coaxial free-jet simulation with species | Felipeb | FLUENT | 3 | August 2, 2010 09:27 |
