simpleFoam crash fast!
Like Tree1Likes
Old   August 10, 2013, 02:16
Default simpleFoam crash fast!
izna O'connor
izna is on a distinguished road
Hi..
after meshing my case successfully, I run simpleFoam, to obtain the following error.
can anyone tell me what should i do?
> FOAM Warning :
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/Field.C at line 262
Reading "/home/izna/Desktop/Askervein/0/U.boundaryField.inlet" from line 35 to line 43
expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 log in "/lib/i386-linux-gnu/libm.so.6"
#4 Foam::incompressible::atmBoundaryLayerInletVelocit yFvPatchVectorField::atmBoundaryLayerInletVelocity FvPatchVectorField(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#5 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::incompres sible::atmBoundaryLayerInletVelocityFvPatchVectorF ield>::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#6 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/simpleFoam"
#7 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField( Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/simpleFoam"
#8 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/simpleFoam"
#9 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/simpleFoam"
#10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/simpleFoam"
#11
#12 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#13
Floating point exception (core dumped)
izna is offline   Reply With Quote
Old   August 10, 2013, 12:21
Patrick Wollny
Pat84 is on a distinguished road
Looks like you forgot the word "uniform" for your velocity inlet boundary condition
Pat84 is offline   Reply With Quote
Old   August 12, 2013, 00:46
izna O'connor
hi
this is my file for U.. I have not forgotten the word uniform..
#include "include/initialConditions"
dimensions [0 1 -1 0 0 0 0];
internalField uniform $flowVelocity;
boundaryField
#include "include/ABLConditions"
outlet
type zeroGradient;
inlet
type atmBoundaryLayerInletVelocity;
Uref $Uref;
Href $Href;
n $windDirection;
z $zDirection;
z0 $z0;
value $internalField;
zGround $zGround;
kappa 0.4;
terrain_patch0
type uniformFixedValue;
value uniform (0 0 0);
ground
type fixedValue;
top
Uref $Uref;
Href $Href;
n $windDirection;
z $zDirection;
z0 $z0;
zGround $zGround;
kappa 0.4;
#include "include/sideAndTopPatches"
Old   August 12, 2013, 01:56
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
all your "$"-parameters are not set.
I assume you should run a script which replaces all the $-parameters with right value
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 12, 2013, 03:02
izna O'connor
dear Max,
can you please elaborate...
where to define those parameters? i mean which folders?
Old   August 12, 2013, 03:18
-mAx-'s Avatar
Maxime Perelli
I am not experienced with atmBoundaryLayerInletVelocity, but for sure the third line of your U file should look like "internalField uniform (0 0 0);"
where (0 0 0) is the velocity vector for domain initialization.
But you have "internalField uniform $flowVelocity;"
$flowVelocity is a parameter for a script, which should automatically set the velocity vector (understand replace $flowVelocity with the right vector).
So either you get this script, and you run it, or you replace all the "$-parameters" with their right values.
The script is not a part of OF.
Old   August 13, 2013, 03:52
izna O'connor
hi thanks for the reply dear max
can you tell me what does the followingh error means? I get this when i run ./Allrun
running 500,000 cells mesh
Traceback (most recent call last):
File "./runAskervein.py", line 26, in <module>
from PyFoam.RunDictionary.SolutionDirectory import SolutionDirectory
ImportError: No module named PyFoam.RunDictionary.SolutionDirectory
running 5,000,000 cells
Old   August 13, 2013, 03:57
-mAx-'s Avatar
Maxime Perelli
edit "Allrun" file and check what it is supposed to do.
Old   August 13, 2013, 04:03
izna O'connor
echo running 500,000 cells mesh
./runAskervein.py . Askervein_SHM_200 598167.367 6339602.511 10000 10000 30 200 1000 120
echo running 5,000,000 cells
./runAskervein.py . Askervein_SHM_75 598167.367 6339602.511 10000 10000 30 75 1000 120
it is supposed to do the above..
Old   August 13, 2013, 04:09
izna O'connor
i got that case from the net and each i am geting the same error..
Old   August 13, 2013, 04:12
-mAx-'s Avatar
Maxime Perelli
check this script runAskervein.py
Old   August 13, 2013, 04:14
Patrick Wollny
Have you installed pyFoam?
Old   August 13, 2013, 05:00
izna O'connor
On installing the pyFOam and again running ./Allrun.. i obtain the foll error..
File "./runAskervein.py", line 114, in <module>
template = TemplateFile(bmName+".template")
File "/usr/local/lib/python2.7/dist-packages/PyFoam/Basics/TemplateFile.py", line 381, in __init__
escape=None
File "/usr/local/lib/python2.7/dist-packages/PyFoam/ThirdParty/pyratemp.py", line 1190, in __init__
parsetree = p.parse(tmpl)
File "/usr/local/lib/python2.7/dist-packages/PyFoam/ThirdParty/pyratemp.py", line 547, in parse
return self._parse(template)
File "/usr/local/lib/python2.7/dist-packages/PyFoam/ThirdParty/pyratemp.py", line 755, in _parse
self._parse_sub(parsetree, template[curr:], fpos)
File "/usr/local/lib/python2.7/dist-packages/PyFoam/ThirdParty/pyratemp.py", line 578, in _parse_sub
self._testexpr(match.group("sub"), fpos+start)
File "/usr/local/lib/python2.7/dist-packages/PyFoam/ThirdParty/pyratemp.py", line 560, in _testexpr
raise TemplateSyntaxError(err, self._errpos(fpos))
PyFoam.ThirdParty.pyratemp.TemplateSyntaxError: line 2, col 1: invalid syntax (, line 1)
escape=None
Old   August 13, 2013, 05:10
izna O'connor
Max when i do the command its says:
runAskervein.py: command not found
EVen after i installed the pyFoam it says same things.
Old   August 13, 2013, 06:59
-mAx-'s Avatar
Maxime Perelli
with check I meant edit the file and check what it is executing...
For running it, you have to know which arguments etc... you have to enter.
But I don't know exactly what does this script and I suggest you to ignore it and go back to basics: set your BC properly and run simpleFoam.
Old   August 20, 2013, 05:51
Default simpleFoam error due to atmBoundaryLayerInletVelocity
  #16
izna O'connor
Each time same error.. I need help badly
Create time
Create mesh for time = 0
Reading field p
Reading field U
--> FOAM Warning :
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude/Field.C at line 262
Reading "/home/izna/Desktop/AskerveinM/0/U.boundaryField.inlet" from line 35 to line 16
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#4 Foam::incompressible::atmBoundaryLayerInletVelocit yFvPatchVectorField::atmBoundaryLayerInletVelocity FvPatchVectorField(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#5 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::incompres sible::atmBoundaryLayerInletVelocityFvPatchVectorF ield>::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#6 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/simpleFoam"
#7 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField( Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/simpleFoam"
#8 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/simpleFoam"
#9 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/simpleFoam"
#10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/simpleFoam"
#11
#13
Old   August 20, 2013, 06:12
Bernhard
Bernhard is on a distinguished road
This is not correct as
would probably contain
flowVelocity (10 0 0);
this should work fine.
Bernhard is offline   Reply With Quote
Old   August 20, 2013, 06:26
-mAx-'s Avatar
Maxime Perelli
But all the $-parameters should remain in the U-file, or they will be replaced with their rihgt values?
I never used "include/initialConditions
Old   August 20, 2013, 06:29
Bernhard
The correct values will be used. Pretty handy if you need variables at multiple places. You can include any file that you wish. For example, sometimes I include the blockMeshDict in the setFieldsDict, works perfectly fine.
Especially in OF 2.2, there are some advanced possibilities, see: http://www.openfoam.org/version2.2.0/pre-processing.php
Old   August 20, 2013, 06:37
izna O'connor
Hi Bernard Below is my ABL file.. I have configured everyhting step by step and all my $ have been already initialised.. still i get error..
boundaryField
outlet
type zeroGradient;
inlet
Uref $Uref;
Href $Href;
n $windDirection;
z $zDirection;
z0 $z0;
zGround $zGround;
//kappa 0.4;
terrain_patch0
type fixedValue;
ground
type fixedValue;
top
Uref $Uref;
Href $Href;
n $windDirection;
z $zDirection;
z0 $z0;
zGround $zGround;
//kappa 0.4;
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 06:27
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 09:07
simpleFoam crash -> How to solve tH3f0rC3 OpenFOAM 4 May 12, 2011 07:07
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 03:08
