RANS of 3D flow around a square cylinder
Old   February 17, 2021, 09:33
Question RANS of 3D flow around a square cylinder
Jeffrey Johnston
NotDrJeff is on a distinguished road
Hello all,
Firstly a disclaimer: I'm an idiot! I lack a lot of basic understanding of CFD and openFoam, so please be patient with me
I am working on a tutorial I found on wiki.openfoam.com from wolfdynamics. Here's the link. The case is 3D flow past a square cylinder at RE=21,400. The point of the tutorial is to compare RANS and LES turbulent models. The tutorial first uses simpleFoam with RANS. My attempt to run this simulation has lead to a whole heap of questions. See my geometry here: geometry.jpg
1) I know a-priori that this case will lead to vortex shedding (i.e. periodic motion). This immediately made me question why simpleFoam (a steady state solver) is being used. Is it ever "correct" to use a steady state solver for a problem that I know contains unsteady flow (even if it is periodic). Can this approach actually result in an accurate time-averaged flow or will the results always be garbage?
2) A brief google for flow around a square cylinder will show studies using URANS rather than RANS for this problem. What does URANS mean in an openFoam context? Does this simply mean using the RAS turbulence model, but with an unsteady solver (like pimpleFoam)? Or is there more to it than that?
3) Ultimately, my residuals aren't converging. For my initial mesh (which is quite coarse), they plateau around (E-4) - (E-7). I originally thought that while they weren't converging, they were still 'low enough'. But I've since read that the value alone isn't sufficient to judge convergence, but the amount that they drop. I've seen that a drop of (E-3) is considered a converged solution. Is this what I should be looking for? See my residuals here: Residuals_01_Coarse.png
4) The residuals oscillate a lot, but I'm not sure if this is because of the physical problem (oscillating flow) or because of the numerical schemes being used. My understanding of numerical schemes right now could be summed up as: 'use linearUpwind unless you know what your doing'. But in this case I am depending on the tutorial to give me recommended settings. My fvSchmes and fvSolution are below. Is there anything obvious that you think is preventing convergence?
ddtSchemes
    default         steadyState;
gradSchemes
    default         cellLimited Gauss linear 0.5;
    grad(U)         cellLimited Gauss linear 1;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind grad(U);
    div(phi,k) 		bounded Gauss upwind;
    div(phi,omega) 	bounded Gauss upwind;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
      default         Gauss linear limited 1;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited 1;
wallDist
    method	    meshWave;
solvers
    p
        solver           GAMG;
        tolerance        1e-6;
        relTol           0.01;
        smoother         GaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 100;
        mergeLevels      1;
	minIter		 3;
    U
        solver          PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol          0.001;
    k
        solver          PBiCGStab;
        tolerance       1e-08;
        relTol          0.001;
    omega
        solver          PBiCGStab;
        tolerance       1e-08;
        relTol          0.001;
SIMPLE
    nNonOrthogonalCorrectors 2;
    pRefCell        0;
    pRefValue       0;
    consistent on;
    residualControl
        p               1e-3;
        U               1e-3;
        nuTilda         1e-3;
        k               1e-3;
        omega           1e-3;
//SIMPLEC URF
relaxationFactors
    fields
        p               0.7;
    equations
        U               0.7;
        k               0.7;
        omega           0.7;
5) I think that's enough questions for now!
Thank you for taking the time to read through this question. I hope to hear your response soon!
Jeffrey,
Last edited by NotDrJeff; February 17, 2021 at 09:56. Reason: Attachments not attached
NotDrJeff is offline   Reply With Quote
rans, simplefoam convergence, square cylinder, vortex shedding
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 02:19
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
grids for flow over a square cylinder student Main CFD Forum 4 April 21, 2009 06:50
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
