Bad Convergence and Stability for a complicated case |
February 9, 2017, 10:57 |
Arya
Rep Power: 9 |
Hi guys!
I have some problems with the stability and convergence of a case with 70 millions cells and complicated automotive geometry. -Mesh quality (tetra with prism layer): skew <3.5 nonOrtho <60 I'm using a k-omega SST turbulence model with an high reynolds number approach. During the first 600 iterations I use the first order scheme below: ddtSchemes { default steadyState; } gradSchemes { default cellLimited leastSquares 1; grad(U) cellLimited leastSquares 1; } divSchemes { default none; /*--------------Schemi numerici modello STD KOMEGASST-----------------------*/ div(phi,U) bounded Gauss upwind grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; div(div(phi,U)) Gauss linear; } laplacianSchemes { default Gauss linear limited 0.5; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.5; } fluxRequired { default no; p; } wallDist { method meshWave; and coupled solver: solvers { p { solver GAMG; smoother GaussSeidel; tolerance 1e-7; relTol 0.01; nPreSweep 0; nPostSweep 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } Phi { $p; } U { type coupled; solver PBiCICG; preconditioner DILU; tolerance (1e-8 1e-8 1e-8); relTol (0 0 0); } "(k|omega)" { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.1; } /*---------------Aggiunti per il modello termico-------------*/ "(h|e)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.01; } } SIMPLE { nNonOrthogonalCorrectors 0; /*--------------Aggiunti per il modello termico---------------*/ rhoMin rhoMin [1 -3 0 0 0] 0.5; rhoMax rhoMax [1 -3 0 0 0] 2.0; } potentialFlow { nNonOrthogonalCorrectors 10; } relaxationFactors { fields { p 0.2; rho 0.3; } equations { U 0.7; "(k|omega)" 0.5; "(h|e)" 0.7; } } cache { grad(U); } Then a second order scheme: ddtSchemes { default steadyState; } gradSchemes { default cellMDLimited Gauss linear 1; grad(U) cellMDLimited Gauss linear 1; } divSchemes { default none; div(phi,U) bounded Gauss SuperBeeV grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; div(div(phi,U)) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; } wallDist { method meshWave; } and solver: solvers { p { solver GAMG; smoother GaussSeidel; tolerance 1e-7; relTol 0.01; nPreSweep 0; nPostSweep 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } Phi { $p; } U { type coupled; solver PBiCICG; preconditioner DILU; tolerance (1e-8 1e-8 1e-8); relTol (0 0 0); minIter 3; } "(k|omega)" { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.1; } /*---------------Aggiunti per il modello termico-------------*/ "(h|e)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.01; } } SIMPLE { nNonOrthogonalCorrectors 1; /*--------------Aggiunti per il modello termico---------------*/ rhoMin rhoMin [1 -3 0 0 0] 0.5; rhoMax rhoMax [1 -3 0 0 0] 2.0; } potentialFlow { nNonOrthogonalCorrectors 10; } relaxationFactors { fields { p 0.3; rho 0.3; } equations { U 0.7; "(k|omega)" 0.7; "(h|e)" 0.7; } } cache { grad(U); } I tried to use a coupled solver for a steady simulation for the better performance which the coupled solver should have. I've already tried with a segregated approach but the results are the same. My problem is that the residual of the pressure never go under 10e-2 and the aerodynamic coefficients are unstable without a good convergence. When I switch to second order approach the residual are stable but always high, especially the pressure, whereas the coefficients always unstable. Is there some problems with the numerical schemes? How can I improve my solver? Thank you all for your advices. Regards |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Convergence Stability Issues | ts_swati | Fluent Multiphase | 0 | July 7, 2014 21:11 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 07:51 |
Convergence and flow stability | Prevani Kistan | Main CFD Forum | 3 | November 12, 2004 20:23 |
Stability and convergence criteria | Adriana | Main CFD Forum | 7 | October 10, 2002 20:36 |
