Falling Droplet using InterFoam
Old   October 16, 2013, 12:28
Default Falling Droplet using InterFoam
Kostis
cosbergel is on a distinguished road
Hi guys,
I am trying to simulate a 3D droplet falling due to gravity forces with interFoam as simple as that. When the droplet reaches a velocity I will put it in a jet flow using mapFields. I have encountered some strange things and I cant even do the first part.
a) Should I change the pressure inside the droplet due to the surface tension? p=2*sigma/r. What about the distribution of pressure inside the droplet due to gravity?
b) Do you believe that the outcome would be the same if I enter a velocity in funkySetFieldsDict?
c) Finally, the droplet disintergrates very quickly before it reaches the velocity (1m/s) which is totally unnatural. Why is that? (personally, I do not think it is about contact angle)
Thank you for you time
Kostis
cosbergel is offline   Reply With Quote
Old   November 12, 2013, 18:22
Shawn Fotovati
sfotovati is on a distinguished road
You should not change the pressure. Solver must calculate it during the solution.
If droplet disintegrates, I believe it is due to mesh, change the mesh and see if it is improved.
I have another problem; Right before droplet hits the surface, it stops moving, and hangs around in the air! I have no idea why this happens for my case!
sfotovati is offline   Reply With Quote
Old   December 2, 2013, 17:30
btsusi is on a distinguished road
cosbergel, I have been having trouble with a 3D droplet behaving almost the same way you described. My grid is refined to .1mm spacing for a 2mm droplet which I thought was sufficient. An order of magnitude refinement did not help. Were you able to figure out your problem? I was using multiphaseInterFoam, but the advice should probably be similar for both.
I appreciate any help!
btsusi is offline   Reply With Quote
Old   December 3, 2013, 05:15
Kostis
@ sfotovati as far as the pressure is concerned, you are right that the solver calculates the pressure inside the droplet but I found out that it is better to put it as an initial condition because otherwise you ll have perturbations on the surface of the droplet.
I think that you have put wrong boundary condition on the wall.
@btsusi I manage to solve my problem firstly by not using dynamic refinement and then by changing the div schemes (specially for alpha1) for interFoam and interDyMFoam which I had it finally working. In my opinion satisfactory number of cells inside a droplet is 50- 100.
Regards,
Kostis
Old   December 3, 2013, 09:10
cosbergel,
Thank you for the quick response, I will try your advice!
Old   May 16, 2018, 05:21
Saicharan
wavefunction is on a distinguished road
Hello cosbergel! I am currently running a simulation on evaporation of a sessile droplet. The same problem of droplet disintegration happens to me too. Do you have any tips on solving this? Should I change the div schemes to a bounded scheme like Gauss upwind?
wavefunction is offline   Reply With Quote
Modelling falling solid sphere using interFoam VOF model eelcovv OpenFOAM Running, Solving & CFD 6 August 7, 2021 21:52
droplet falling - VOF bohis FLUENT 1 July 10, 2013 04:28
falling droplet deforms unusually- Multiphase MNHasan FLUENT 2 July 10, 2013 04:25
sphere falling down droplet naderafshar FLUENT 1 December 24, 2011 10:30
Interfoam Droplet under shear test case adona058 OpenFOAM Running, Solving & CFD 3 May 3, 2010 18:46
