Allclean deleting polyMesh directory and not working runParallel after update
Old   February 14, 2017, 06:01
Default Allclean deleting polyMesh directory and not working runParallel after update
Hagen
HagenC is on a distinguished road
Hi everyone,
I used to use OpenFoam version 2.3.1, now I wanted to use the newer version v1612+. I had both of them installed in Virtual Boxes with newly setup Ubuntu. (Ubuntu14.04 for OF2.3.1 Ubuntu16.04 for OFv1612+).
Then I copied one of my cases, which run in OF2.3.1 perfectly to OFv1612+.
I can run the case in the new version as well, but I struggle with two problems:
  1. When I use Allclean my constant/polyMesh folder is deleted as well, which I need as base for snappyHexMesh and which was not deleted in the old version.
  2. It seems like using runParallel does not work for me any more.
    runParallel pisoFoam 4
    gives the error:
    Usage: pisoFoam [OPTIONS]
    options:
      -case <dir>       specify alternate case directory, default is the cwd
      -decomposeParDict <file>
                        read decomposePar dictionary from specified location
      -noFunctionObjects
                        do not execute functionObjects
      -parallel         run in parallel
      -postProcess      Execute functionObjects only
      -roots <(dir1 .. dirN)>
                        slave root directories for distributed running
      -srcDoc           display source code in browser
      -doc              display application documentation in browser
      -help             print the usage
    Using: OpenFOAM-v1612+ (see www.OpenFOAM.com)
    Build: v1612+
    [0]
    [0]
    [0] --> FOAM FATAL ERROR:
    [0] Wrong number of arguments, expected 0 found 1
    [0]
    [0]
    FOAM parallel run exiting
    [0]
    MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
    with errorcode 1.
    NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
    You may or may not see output from other processes, depending on
    exactly when Open MPI kills them.
I would be very happy, if someone has Ideas on that. By the way running
mpirun -np 4 pisofoam -parallel
works fine.
Thanks in advance!
Hagen
HagenC is offline   Reply With Quote
Old   February 15, 2017, 03:34
Default Solved polyMesh Issue
Hagen
The problem was that I had my blockMeshDict file in the polyMesh folder. It was no problem for running the case, OF found it there, but with ./Allclean it was deleted together with the polyMesh folder. I moved the blockMeshDict file to system folder, that solved the first problem.
Second one is still an issue.
Best,
Hagen
Old   February 15, 2017, 05:20
Default Solved runParallel
Hagen
To solve the second problem just omitt the number
runParallel pisoFoam -parallel
The number of processors can be specified by
runParallel -np 4 pisoFoam -parallel
but without specifying the number, the number according to decomposeParDict will be taken automatically.
Old   February 16, 2017, 05:56
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
You could try these instead (for 1612), note that your -parallel option shouldn't be there.
runParallel -decomposeParDict system/someDecompDict pisoFoam
olesen is offline   Reply With Quote
Old   February 17, 2017, 02:43
Hagen
Thank you Olesen,
you are right, the -parallel option is obsolete.
Best,
Hagen
