BC for a water-air system
Like Tree1Likes
  • 1 Post By sati
Old   February 20, 2017, 04:30
Default BC for a water-air system
paolo
iopenfoam is on a distinguished road
Hi everybody!
the aim of my simulation is to evaluate the interaction in between a flux of air through a flux of water, like in the picture-1 attached.
The solver I'm using is interFoam and the tutorial I used to start is damBreak.
First I tried to implement the inlet flow of water , with turbulent condition, without air flux, and I expanded the volume of study
The boundary conditions I applied are as in the attached files (BC.zip). I choose them based on those of the damBreak tutorial and from a tutorial at this page:
http://www.holzmann-cfd.de/index.php...pump-cyclic-bc
What I get is an error about the number of iterations, as in the attached file (log.interFoam.zip). The log file is shorter than the real one beacause of file dimension.
So, which should be in general the correct (or standard) BC for a simulation like this (and with the air-flux applied)?
Thanks in advance for any kind reply.
Regards
Paolo
iopenfoam is offline   Reply With Quote
Old   February 20, 2017, 06:39
sati is on a distinguished road
It looks like you used a fixed time step, which causes the courant number to increase too much.
Set adjustTimeStep to "yes" and max courant number to 0.5 in your controldict and it should be better.
iopenfoam likes this.
sati is offline   Reply With Quote
Old   February 22, 2017, 03:21
paolo
Hi Sati,
thanks for your hint, it works fine now!
I guess the problem was about a high velocity of the fluid while falling, so with high velocity , but same time step and cell size, the Courant number increased too much and affected convengence.
Thanks a lot!
Regards
Mass Transfer Between AIR and WATER Math13570 CFX 12 June 29, 2016 08:14
air into box filled with water, outflow for water at bottom dieterdanger Fluent Multiphase 0 July 16, 2015 16:11
Is it possible to integrate air through a system with mixture of air and water? Hale OpenFOAM Post-Processing 1 September 30, 2013 08:57
I am NOT getting right pressure at the air inlet in water column kcfd FLUENT 0 November 24, 2012 23:14
Boiling of water with hot air Dr. Flow Squad CFX 2 July 27, 2009 07:37
