Error from pEqn in PISO loop in compressible solver |
February 22, 2017, 06:22 |
Dear FOAMers,
I am trying to solve the temperature-induced pressure gradient in liquid helium (confined in a channel) occurring from a discharge of high energy. For this, I need to solve for the coupled momentum and energy equations and compute the thermodynamic properties using an external fortran module. For this purpose, I am building a compressible solver using the chtMultiRegionFoam solver as a reference, and am now able to run the solver but it keeps crashing at the time step "0.107" (see error from the log hereunder) no matter what parameters I set in the fvSolution and fvSchemes dictionaries: Code:
Region: hell_channel Courant Number mean: 3.6443497e-06 max: 6.7134329e-05 Time = 0.117 Solving for superfluid helium region hell_channel diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 0.012916636, Final residual = 2.1946216e-14, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.0080626801, Final residual = 9.8190616e-15, No Iterations 1 DILUPBiCG: Solving for Ux, Initial residual = 0.00011588099, Final residual = 9.1147225e-17, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 8.5073936e-05, Final residual = 1.2611083e-16, No Iterations 1 DILUPBiCG: Solving for hi, Initial residual = 2.5778752e-08, Final residual = 2.5778752e-08, No Iterations 0 Min/max T:3.0016428 3.0445642 GAMG: Solving for p, Initial residual = 0.0002906377, Final residual = 3.8736628e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (hell_channel): sum local = 8.5116225e-07, global = 4.9213372e-13, cumulative = -0.0010918572 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib64/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const at ??:? #6 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #7 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #8 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvMatrixSolve.C:82 #10 at ~/OpenFOAM/OpenFOAM-2.3.0/applications/solvers/heatTransfer/CompressibleHeSolver/./fluid/pEqn.H:78 (discriminator 1) #11 __libc_start_main in "/lib64/libc.so.6" #12 at ??:? Floating point exception Code:
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( pDDtEqn - fvm::laplacian(rhorAUf, p) ); pEqn.solve ( mesh.solver ( p.select ( ( oCorr == nOuterCorr-1 && corr == nCorr-1 && nonOrth == nNonOrthCorr ) ) ) ); Code:
p { solver GAMG; tolerance 1e-7; relTol 0.01; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 60; agglomerator faceAreaPair; mergeLevels 1; } pFinal { $p; tolerance 1e-7; relTol 0; } Code:
Region: hell_channel Courant Number mean: 3.5834383e-06 max: 6.7071608e-05 Time = 0.116 Solving for superfluid helium region hell_channel diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 0.013165873, Final residual = 2.1176503e-14, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.0081476332, Final residual = 9.3894979e-15, No Iterations 1 DILUPBiCG: Solving for Ux, Initial residual = 0.00011809902, Final residual = 8.8268892e-17, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 8.5991334e-05, Final residual = 1.2143285e-16, No Iterations 1 DILUPBiCG: Solving for hi, Initial residual = 2.5511043e-08, Final residual = 2.5511043e-08, No Iterations 0 Min/max T:3.0016456 3.0448337 GAMG: Solving for p, Initial residual = 0.00027577967, Final residual = 2.4234806e-10, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (hell_channel): sum local = 8.1632713e-07, global = -3.0635965e-12, cumulative = -0.0010918571 GAMG: Solving for p, Initial residual = 1.9836363e-06, Final residual = 2.2204109e-11, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (hell_channel): sum local = 8.1632298e-07, global = -3.5110486e-11, cumulative = -0.0010918572 Solving for solid region solid1 DICPCG: Solving for T, Initial residual = 0.0027234834, Final residual = 4.5801085e-08, No Iterations 6 Min/max T:min(T) [0 0 0 1 0 0 0] 3.0018298 max(T) [0 0 0 1 0 0 0] 29.987348 Solving for solid region solid2 DICPCG: Solving for T, Initial residual = 0.0026282575, Final residual = 4.0420011e-08, No Iterations 8 Min/max T:min(T) [0 0 0 1 0 0 0] 3.0019453 max(T) [0 0 0 1 0 0 0] 29.985524 ExecutionTime = 16.67 s ClockTime = 17 s Thank you all ! |
Density-based, fully-coupled, compressible solver in OpenFOAM? | francesco_capuano | OpenFOAM Running, Solving & CFD | 7 | November 20, 2018 13:12 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Cryogenics, compressible multiphase and heat transfer solver | mturcios777 | OpenFOAM Programming & Development | 3 | March 22, 2012 10:11 |
Optimizing the solution of tridiagonal linear systems | CCKM | Main CFD Forum | 14 | March 14, 2012 07:40 |
compressible solver for engine simulations | Peter_600 | OpenFOAM | 6 | June 9, 2011 13:40 |
