Dynamic mesh within a dynamic mesh
Like Tree5Likes
  • 1 Post By louisgag
  • 1 Post By bullmut
  • 3 Post By louisgag
Old   October 8, 2013, 15:33
Default Dynamic mesh within a dynamic mesh
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Hello all,
I've sucessfully used GGI and AMI in the past to simulate a rotating part within a fixed domain.
Now, I want to know if it is possible to have a rotating mesh embed within another rotating mesh. Has anyone achieved this?
Thanks
-Louis
louisgag is offline   Reply With Quote
Old   October 8, 2013, 21:24
minger is on a distinguished road
Wow, I was actually getting ready to post the same question. I have looked through the mixer2d tutorials in pimpleDyMFoam and think I have a decent grasp of what's going on there. However, I am hoping to be able to "nest" a rotating zone within another.
minger is offline   Reply With Quote
Old   October 29, 2013, 08:30
louisgag's Avatar
Louis Gagnon
For those wondering if it works, yes it does. I had to do a tiny C++ modification to ensure that the origin of the internal AMI zone rotates with the external one and voilà.
-Louis
Old   October 31, 2013, 20:12
Would you mind attaching a case zipped up?
Old   November 6, 2013, 16:25
louisgag's Avatar
Louis Gagnon
The project is confidential so I can't put all the data online, but it should be fairly easy to replicate.
In my case I modified oscillatingRotatingMotion.C as such,
Foam::solidBodyMotionFunctions::oscillatingRotatingMotion::
transformation() const
    scalar t = time_.value();
    vector eulerAngles = amplitude_*sin(omega_*t);
    // Convert the rotational motion from deg to rad
    eulerAngles *= pi/180.0;
    scalar omegaBlop_ =  73.304; // outter AMI zone info
    scalar originBlop_ =  3.048;
    scalar radBlop_ =  0.6096;
    scalar omgOffsetBlop = pi/2; // offset from the right hand axis when simulation starts
    vector blop_ = vector (originBlop_+radBlop_*cos(omegaBlop_*t + omgOffsetBlop),
            originBlop_+radBlop_*sin(omegaBlop_*t + omgOffsetBlop), 0);
//    Info<< "LOUIS: " << blop_ << endl;
    quaternion R(eulerAngles.x(), eulerAngles.y(), eulerAngles.z());
//    septernion TR(septernion(origin_)*R*septernion(-origin_));
    septernion TR(septernion(blop_)*R*septernion(-blop_));
    Info<< "solidBodyMotionFunctions::oscillatingRotatingMotion::"
        << "transformation(): "
        << "Time = " << t << " transformation: " << TR << endl;
And in the dynamic mesh dictionary I ensure that the outer AMI zone angular velocity matches the modified one in the C++ file...
Old   February 26, 2014, 06:03
louisgag's Avatar
Louis Gagnon
here is the code for OpenFoam 2.3.x, copy in your user folder and
wmake libso
sylvester likes this.
Old   February 26, 2014, 06:14
louisgag's Avatar
Louis Gagnon
Along with a test case from which I removed the confidential data... You will need to change the foil U boundary condition because it is a one I've coded myself...
http://ecbiz103.inmotionhosting.com/...leEmbedAMI.zip
any feedback is welcome !
Old   March 28, 2014, 06:34
Diego Angeli
diego_angeli is on a distinguished road
Hi Louis,
here Diego from UNIMORE. We don't know each other but I think we will soon
I just downloaded your myOscillatingRotatingMotion and the test case, thanks for sharing and congratulations for the nice work.
If it's ok for you I will try to use them on a similar case as yours, for CROP..
I'll let you know ASAP how are we faring on that.
Regards
diego_angeli is offline   Reply With Quote
Old   April 2, 2014, 13:13
louisgag's Avatar
Louis Gagnon
Hello Diego,
It will be a pleasure to collaborate with you. Please use this thread to communicate with me so that everyone can follow. Obviously we'll have to avoid confidential project data.
Regards,
-Louis
Old   April 14, 2014, 07:47
Diego Angeli
Hi Louis,
thanks for the support.
So, Andrea and me managed to reproduce a moving mesh analogous to your case, starting from a mesh generated from us with another meshing tool. The workflow is ok on the mesh side.
Now we should work on the boundary condition for U on the foils, then maybe we will come back to you to agree on the case setup.
Best regards
Old   December 11, 2015, 03:23
louisgag's Avatar
Louis Gagnon
The link for the test case I had posted above is broken. Please use the following instead: louisgagnon.com/temporaire/exampleEmbedAMI.zip
-Louis
Old   September 23, 2016, 07:13
Gareth
bullmut is on a distinguished road
Hi Louis
from what i read in this thread i think i am trying to achieve the same thing.
I am trying to implement you test case and have compiled your libmyDynamicFvMesh.so
However when i run the case it is trying to load "libmyFiniteVolume.so", to allow for the definition of your foils as patch type myMovingWallSlip. Can you explain your modification in the making of this patch type of supply files for the wmake of the latter .so ?
Regards
bullmut is offline   Reply With Quote
Old   September 23, 2016, 09:20
louisgag's Avatar
Louis Gagnon
Hi Gareth,
I choose to use a boundary condition that imposes a slip and respects the moving wall velocity for my simulation: http://www.cfd-online.com/Forums/ope...tml#post509989
You can use another boundary condition if you prefer...
Regards,
-Louis
Old   September 24, 2016, 05:27
Gareth
Hi Louis
Thanks for the info and explanation.
I was trying to run the code as is, with minimal alterations. But i get what you mean by a different BC.
Thanks again for the code. Kinda what i needed, but definitely a step in the right direction.
Regards
louisgag likes this.
Old   March 1, 2017, 11:03
louisgag's Avatar
Louis Gagnon
Dear Everyone,
I've created a GitHub repository with the updated version of the code and test case for OpenFOAM-4.x
https://github.com/louisgag/OpenFOAM-embedded-AMI
Enjoy,
-Louis
RK_Token, AnnaF and maasyraf3 like this.
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 10:42
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 22:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 08:03
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
