Solving forces & coeffs
Like Tree1Likes
  • 1 Post By kera
Old   May 2, 2012, 09:37
Default Solving forces & coeffs
Sergey Zinkevich
Astarta is on a distinguished road
Hello every1!
I`ve troubles with solving forces an coeffs
I use SRFSimpleFoam :
"--> FOAM Warning :
From function void forces::read(const dictionary&)
in file forces/forces.C at line 309
Could not find Uabs, p in database. "
conrtolDict:
type forces
functionObjectLibs ("libforces.so);
patches (MODEL);
pName p;
UName Uabs;
log true;
rhoName rhoInf;
rhoInf 1.225;
CofR (0 0 0);
outputControl timeStep;
outputInterval 1;
Any help will be appreciated
Best regards,
Astarta
Astarta is offline   Reply With Quote
Old   May 3, 2012, 02:58
colinB is on a distinguished road
just a guess from the information you provided:
patches (MODEL);
pName p;
UName Uabs;
do these three entities contain the name of the patch
you want to calculate the forces on (patch) and the name
of the file specifying the pressure values (pName) and
velocity values (UName)
and are these files located in a folder named 0,
for the problem is:
and the question is y? usually this is a naming or storing issue.
I hope I could contribute
regards
colinB is offline   Reply With Quote
Old   May 4, 2012, 05:08
Sergey Zinkevich
Thanks! It helped, noweverything`s ok!
Old   March 9, 2017, 07:45
Niranjan Prabhu
niran is on a distinguished road
--> FOAM FATAL IO ERROR:
keyword origin is undefined in dictionary "/home/user/OpenFOAM/user-2.4.0/run/work/3_waveflume/system/controlDict.functions.forces"
file: /home/user/OpenFOAM/user-2.4.0/run/work/3_waveflume/system/controlDict.functions.forces from line 10 to line 24.
forces
type forces;
functionObjectLibs ( "libforces.so" );
timeInterval 1;
log yes;
patches ( cylinder );
pName pd;
UName U;
rhoName rhoInf; // Indicates incompressible
log true;
rhoInf 1000;
any help please
niran is offline   Reply With Quote
Old   March 9, 2017, 08:35
Ricky
kera is on a distinguished road
forces
type forces;
timeInterval 1;
log yes;
pName pd;
UName U;
log true;
rhoInf 1000;
any help please
centre of rotation is missing in your forces functionObject.
CofR (0 0 0) // also depends on your case
niran likes this.
If it is easy, then something is fishy!
kera is offline   Reply With Quote
Old   March 9, 2017, 09:31
Smile
Niranjan Prabhu
thank you KERA now it is running
CofR required ?
In waves2Foam there is no p file i changed to pd which is available in this solver but unit of both p & pd are not same. Is any problem will come because of this?
coeffs, forces, srfsimplefoam
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
