Opening temperature
Old   February 13, 2017, 12:37
Default Opening temperature
alberto
dewey is on a distinguished road
Hi.
I am trying to simulate natural convection inside a pipe.
The boundary conditions are as follows:
The pipe is divided into three parts,
- The middle one has a temperature of 1300
- The others are adiabatics
- The sides are OPENINGS, can be inlet or/and outlet
How can i put this openings boundary condition in U and P_pgh?
How can i put the OPENING TEMPERATURE without force the flow, i mean, without fixed the outflow temperature on that side; like wall temperature been an opening.
On ANSYS CFX i can put this boundary condition definining an opening and one opening temperature.
Thanks for your time.
dewey is offline   Reply With Quote
Old   February 27, 2017, 10:27
Joachim Herb
jherb is on a distinguished road
You are looking for the inletOutlet boundary condition.
jherb is offline   Reply With Quote
Old   February 28, 2017, 03:15
KateEisenhower is on a distinguished road
Hello Alberto and Joachim,
I am not sure that this is right. With inletOutlet Alberto would have to specify the inflow temperature as a scalar. But how should he know the value?
What about zeroGradient?
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   March 2, 2017, 17:24
Joachim Herb
I think this is exactly, what inletOulet boundary does. For outward flow direction it behaves like zeroGradient. For inflows you set the temperature with inletValue.
Old   March 9, 2017, 15:02
alberto
Hi i have another question, i am trying to simulate a water in a vertical pipe as in pictures, in the middle of the pipe i have a wall some temperature hotter than the water, can you tell me what am i doing wrong? the water dosnt heat passing the wall hot, i dont know what TEMPERATURE Bc i have to put at outlet in order to dont force this.
If i put a fixed value, i am forcing the outlet temperature right? and i dont want that.i already try with zeroGradient. I want the temperature of the water heated.
thanks for you answer.
File Type: jpg Captura de pantalla de 2017-03-09 13-51-03.jpg (70.3 KB, 10 views)
File Type: jpg Captura de pantalla de 2017-03-09 13-51-45.jpg (92.8 KB, 12 views)
Old   March 16, 2017, 03:00
Hola Alberto,
have you applied fixedValue at the inlet and at the walls? What happened when you tried zeroGradient at the outlet?
Best regards,
Kate
[ANSYS Meshing] Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit RPjack ANSYS Meshing & Geometry 1 June 20, 2019 07:11
Static temperature and Total temperature Jong-Yoon FLUENT 0 September 25, 2016 01:42
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 06:08
difference of temperature HKH FLUENT 0 January 28, 2010 02:45
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 17:31
