Weird result in simulation of Taylor-Couette Flow
3 Attachment(s)
Hi everybody,
I have recently immigrated from Fluent to OpenFOAM, so maybe this question looks weird :) I'm solving classic flow of Taylor-Couette (the flow in narrow gap of two rotating concentric cylinders). The results of simulation in Fluent are exactly what I was expecting, but OpenFOAM gives strange results, as you can see in the attached photos. The vectors are slices of the 3D domain, the inner cylinder is rotating with 0.6 rad/sec and the outer one is fixed. As it's apparent from the photos there's a linear velocity for the outer cylinder which is certainly wrong. there's no inlet/outlet BC, the BC for the inner cylinder is rotatingWallVelocity and the BC for the top and bottom faces is symmetry. Any idea is appreciated |
You might want to check the velocity boundary condition on the outer cylinder.
Is it fixed to (0 0 0)? Best regards, Fumiya |
Tnx for ur reply, actually I also changed the BC for outer cylinder to rotatingWallVelocity with zero angular velocity to force the wall to be stationary, but the results are still the same, here is the U BC for ur consideration
top |
Could you upload your case?
yeah, sure,
please find the case using the link below: https://www.dropbox.com/s/87849pj5aecdtvh/OpenFOAM.tar.gz?dl=0 |
I could be wrong, but it looks like a visualisation problem from paraview. Have you enabled the "scale mode" option in the glyphs options of paraview? |
1 Attachment(s)
but when I change it to "vector" the vectors get rational. I think since I wanna visualize vectors of velocity, I have to select this one in "scale mode" |
