Arash
Rep Power: 10 ![]() |
I want to simulate the effect of landslide motion on stratified reservoir and obtain the velocity field on vertical direction (2D vertical) by using openfoam, I would be so grateful if you would tell me which solver in openfoam is appropriate for this simulation? Best regards, |
Retired Super Moderator
Bruno Santos
Rep Power: 129 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: Depends on whether the "land" is gravel based (particles that are released) or a single block (predefined shape or at least predefined shapes).
The solver interDyMFoam is possibly what you looking for (can simulate 2 phases of fluids, e.g. air and water). See and run the tutorials inside the sub-folder "multiphase/interDyMFoam" for that solver. I would say that the tutorial case "damBreakWithObstacle" is the closest there is in there to your case, although I believe the obstacle is a solid object.
Arash
Thank you very much for your kind attention.
The land is a single solid box. Sent from my iPhone using CFD Online Forum mobile app |
Bruno Santos
Quick answer: Sorry, I only remembered a few days later that the "damBreakWithObstacle" tutorial does not have a solid object. The tutorial in that folder that does have a solid object is the one named "floatingObject".
Arash
Huang, Chiung Shu
Rep Power: 8 ![]() |
hi all,
I wonder do you successed simulating the case that you want to do, because I am trying to do the same thing as you. If you make it work, can you advise me how to do it. The thing I am doing now is trying to simulate a box slide down with a slope (5 degree),and to see it sliding into water and to see how the water being reaction, and I am using olaDyMFlow solver basically same as interDymFoam solver. And I am trapping with the geometry and mesh problem and without any idea, just keeping try and error for such a long time,and feel a little helpless, so come here for help. ![]() ![]() ![]() best regards to all, James |
Display Modes | |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
Waterbell Simulation | o.b.m | Fluent Multiphase | 1 | November 5, 2015 05:55 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
