enginpower |
May 4, 2017 08:35 |
This is the log file solver outputed, if it can help:
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.1
Exec : rhoSimpleFoam
Date : May 04 2017
Time : 14:19:39
Host : "engine-VirtualBox"
PID : 4696
Case : /home/engine/OpenFoam/diffuse_rhoSimpleFoam
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.0001
field e tolerance 0.001
field "(k|epsilon|omega)" tolerance 0.001
Reading thermophysical properties
Selecting thermodynamics package
type hePsiThermo;
mixture pureMixture;
transport sutherland;
thermo janaf;
equationOfState PengRobinsonGas;
specie specie;
energy sensibleInternalEnergy;
Reading field U
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
No MRF models present
No finite volume options present
Starting time loop
Time = 1
smoothSolver: Solving for e, Initial residual = 1, Final residual = 0.0540073, No Iterations 1
GAMG: Solving for p, Initial residual = 1, Final residual = 0.00371374, No Iterations 1
time step continuity errors : sum local = 0.146365, global = 0.074303, cumulative = 0.074303
rho max/min : 4.84782 2.38329
smoothSolver: Solving for epsilon, Initial residual = 0.172435, Final residual = 0.00961314, No Iterations 2
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0693484, No Iterations 2
ExecutionTime = 39.26 s ClockTime = 39 s
Time = 2
smoothSolver: Solving for e, Initial residual = 0.206248, Final residual = 0.0125807, No Iterations 1
GAMG: Solving for p, Initial residual = 0.497519, Final residual = 0.00163633, No Iterations 1
time step continuity errors : sum local = 0.0922393, global = 0.00722332, cumulative = 0.0815263
rho max/min : 4.68042 2.30108
smoothSolver: Solving for epsilon, Initial residual = 0.081466, Final residual = 0.00135644, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.135448, Final residual = 0.00222524, No Iterations 4
ExecutionTime = 60.8 s ClockTime = 61 s
Time = 3
smoothSolver: Solving for e, Initial residual = 0.0921914, Final residual = 0.0067252, No Iterations 1
GAMG: Solving for p, Initial residual = 0.295628, Final residual = 0.00206877, No Iterations 1
time step continuity errors : sum local = 0.1348, global = -0.0479959, cumulative = 0.0335304
rho max/min : 4.5214 2.22033
smoothSolver: Solving for epsilon, Initial residual = 0.0482015, Final residual = 0.00140061, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.0592527, Final residual = 0.00145718, No Iterations 4
ExecutionTime = 81.9 s ClockTime = 82 s
Time = 4
smoothSolver: Solving for e, Initial residual = 0.0537717, Final residual = 0.0046956, No Iterations 1
GAMG: Solving for p, Initial residual = 0.184845, Final residual = 0.00221746, No Iterations 1
time step continuity errors : sum local = 0.157532, global = -0.0805149, cumulative = -0.0469844
rho max/min : 4.37033 2.14308
smoothSolver: Solving for epsilon, Initial residual = 0.0371772, Final residual = 0.00132592, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.0359271, Final residual = 0.0011415, No Iterations 4
ExecutionTime = 102.71 s ClockTime = 102 s
Time = 5
smoothSolver: Solving for e, Initial residual = 0.037143, Final residual = 0.00366518, No Iterations 1
GAMG: Solving for p, Initial residual = 0.119611, Final residual = 0.00216066, No Iterations 1
time step continuity errors : sum local = 0.162309, global = -0.094971, cumulative = -0.141955
rho max/min : 4.22682 2.06984
smoothSolver: Solving for epsilon, Initial residual = 0.0308441, Final residual = 0.00137104, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.0255359, Final residual = 0.000959661, No Iterations 4
ExecutionTime = 123.21 s ClockTime = 123 s
Time = 6
smoothSolver: Solving for e, Initial residual = 0.0281171, Final residual = 0.000449398, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0798722, Final residual = 0.00201198, No Iterations 1
time step continuity errors : sum local = 0.155986, global = -0.0975481, cumulative = -0.239504
rho max/min : 4.09048 2.00056
smoothSolver: Solving for epsilon, Initial residual = 0.0354407, Final residual = 0.00139249, No Iterations 4
bounding epsilon, min: -3030.03 max: 17421.2 average: 207.091
smoothSolver: Solving for k, Initial residual = 0.0198908, Final residual = 0.000838357, No Iterations 4
ExecutionTime = 143.7 s ClockTime = 143 s
Time = 7
smoothSolver: Solving for e, Initial residual = 0.0222361, Final residual = 0.000380718, No Iterations 2
GAMG: Solving for p, Initial residual = 0.054566, Final residual = 0.00182607, No Iterations 1
time step continuity errors : sum local = 0.144461, global = -0.093211, cumulative = -0.332715
rho max/min : 3.96095 1.93506
smoothSolver: Solving for epsilon, Initial residual = 0.0336136, Final residual = 0.00138304, No Iterations 4
bounding epsilon, min: -398.097 max: 18157.5 average: 207.952
smoothSolver: Solving for k, Initial residual = 0.0164301, Final residual = 0.000750733, No Iterations 4
ExecutionTime = 163.52 s ClockTime = 163 s
Time = 8
smoothSolver: Solving for e, Initial residual = 0.0183909, Final residual = 0.000333399, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0381647, Final residual = 0.00164253, No Iterations 1
time step continuity errors : sum local = 0.131653, global = -0.0852954, cumulative = -0.41801
rho max/min : 3.8379 1.87311
smoothSolver: Solving for epsilon, Initial residual = 0.0452828, Final residual = 0.00157203, No Iterations 4
bounding epsilon, min: -5692.65 max: 18873.5 average: 208.924
smoothSolver: Solving for k, Initial residual = 0.0140894, Final residual = 0.00068383, No Iterations 4
ExecutionTime = 183.43 s ClockTime = 183 s
Time = 9
smoothSolver: Solving for e, Initial residual = 0.0156991, Final residual = 0.00029791, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0276336, Final residual = 0.000595807, No Iterations 2
time step continuity errors : sum local = 0.0477531, global = -0.0296898, cumulative = -0.4477
rho max/min : 3.72101 1.81453
smoothSolver: Solving for epsilon, Initial residual = 0.0441157, Final residual = 0.00148421, No Iterations 4
bounding epsilon, min: -745.382 max: 19567.6 average: 209.922
smoothSolver: Solving for k, Initial residual = 0.0125306, Final residual = 0.000631366, No Iterations 4
ExecutionTime = 202.69 s ClockTime = 202 s
Time = 10
smoothSolver: Solving for e, Initial residual = 0.0136794, Final residual = 0.000269679, No Iterations 2
GAMG: Solving for p, Initial residual = 0.020065, Final residual = 0.000521133, No Iterations 2
time step continuity errors : sum local = 0.0423525, global = -0.0250551, cumulative = -0.472755
rho max/min : 3.60996 1.75873
smoothSolver: Solving for epsilon, Initial residual = 0.0661285, Final residual = 0.00193734, No Iterations 4
bounding epsilon, min: -12255.9 max: 20241.8 average: 211.066
smoothSolver: Solving for k, Initial residual = 0.0117622, Final residual = 0.000553884, No Iterations 4
ExecutionTime = 221.44 s ClockTime = 221 s
Time = 11
smoothSolver: Solving for e, Initial residual = 0.0121028, Final residual = 0.000246455, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0152189, Final residual = 0.000464024, No Iterations 2
time step continuity errors : sum local = 0.037845, global = -0.0211324, cumulative = -0.493887
rho max/min : 3.50446 1.70564
smoothSolver: Solving for epsilon, Initial residual = 0.0631682, Final residual = 0.00171955, No Iterations 4
bounding epsilon, min: -1319.43 max: 21681.1 average: 212.209
smoothSolver: Solving for k, Initial residual = 0.0100108, Final residual = 0.000557271, No Iterations 4
ExecutionTime = 240.19 s ClockTime = 240 s
Time = 12
