Having dificulties creating an inverse set-up of the planeWall2D tutorial
so i've been working on cht and basically i have to create an inverse of planeWall2D problem or multiregion heater to create 2 walls and have air between them. which is basically reverse of planeWall2d which has two air layers and one wall. i'm trying to emulate a fin
please help!!! may god bless,:( [Moderator note: Title of the thread was changed based on post, from "please help" to the current descriptive title.] |
Dear nayak,
I guess I am speaking for eveybody if I say that your thread will not be answered based two things:
Good luck. |
sorry sir,
still a newbie trying to learn. i think this will help you understand my problem. https://img2.brain4.photobox.com/777...6e60dd105a.jpg |
If you don't need to know what happens inside the walls they may be threaten as boundary conditions. You have to specify what should happen at the upper and lower boundary of your air column. Free inflow and outflow? Forced convection? Something else? This has to set with a boundary condition too.
sir i'm considering the top and bottom for air to be wall
Greetings to all!
@mikestunna: Please don't write questions inside images :( Since you are asking questions on a public forum, please keep in mind that the objective is that when people help you, others can be helped too in the future. More details are given at the thread: https://www.cfd-online.com/Forums/op...-get-help.html Transcribing what you wrote on the paper: Quote:
As for setting up the case, if you are using OpenFOAM 2.3 or newer, I'm unfortunately unable to help much in this, because there was a critical change made in OpenFOAM that I still haven't managed to find the time to figure out how it can be properly implemented in the tutorial for the "planeWall2D". My advice is to take the tutorial case "heatTransfer/chtMultiRegionFoam/multiRegionHeater" as a base for your case and remove the parts that you don't need. In other words, gradually construct your case based on this tutorial case. Best regards, Bruno |
thank you very much sir.that helped
now i'm trying to add radiation to it.how do i begin with??? i need cht+radiation and i'm facing problems with "agglomeration" & "submap" |
