April 14, 2017, 14:21 |
Constant heat flux boundary condition
Mhamad Mahdi Alloush
Rep Power: 10 |
I am simulating a typical ventilation problem in a room. In the room I have a panel heater which I assume it provides a constant heat flux q''. I am using the solver buoyantBoussinesqSimpleFoam to simulate the problem. When I used externalWallHeatFluxTemperature as a boundary condition for the panel heater, it raises an error saying that the thermo package is required. My question is: Am I putting the right boundary condition or is there any other way to assign a constant heat flux? Thanks in advance! |
April 14, 2017, 17:46 |
Rep Power: 20 |
That is the correct boundary condition. You probably just did some mistake on the syntax.
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Heat Flux as a Profile Boundary Condition | Hitch8 | CFX | 2 | April 22, 2010 13:09 |
