Inlet patch problems
Old   September 23, 2012, 20:42
Default Inlet patch problems
Hugh Ingham
martyn88 is on a distinguished road
Hello Foamers,
I am having trouble getting a simulation to run and the main problem appears to be at my inlet. It is basically a converging diverging nozzle poking into a freestream and I am defining a inlet flow rate at the nozzle and a small coflow above the nozzle.
I have attempted to use the flowrateinletvelocity condition but it appears to not be prescribing a velocity at the inlet, regardless of how high I set the mass flow rate. I have initialised my internal field velocity at 2m/s so all thats happening is the internal field is leaving the domain and being replaced by zero velocity air.
Here is my mesh at the inlet:
I also used a fixed value velocity at the inlet to compare and found the following:
For flowrateinletvelocity:
- what is wrong with my inlet patch? It seems like it is not properly connected or something, like it is blocked.
- why does mass flow rate BC cause no apparent inlet velocity to be defined?
- why is the temperature not propagating (or doing so extremely slowly)?
Fixed value velocity:
- when fixed value velocity is defined, flow is developing, but way too slowly. 20 m/s inlet U should have travelled 4 metres (8 nozzle lengths) in 0.2 secs, however it has not even made the nozzle exit (travelled 10cm max)
Please find attached the checkMesh log
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 1789130
internal faces: 1727110
cells: 586040
boundary patches: 8
point zones: 0
face zones: 1
cell zones: 1
Overall number of cells of each type:
hexahedra: 586040
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
CYCLIC_1 23366 23821 ok (non-closed singly connected)
CYCLIC_2 23366 23821 ok (non-closed singly connected)
FREESTREAM_BOTTOM 812 870 ok (non-closed singly connected)
FREESTREAM_TOP 7784 8091 ok (non-closed singly connected)
INLET 588 631 ok (non-closed singly connected)
INLET_COFLOW 1372 1450 ok (non-closed singly connected)
NOZZLEWALL 2772 2900 ok (non-closed singly connected)
OUTLET 1960 2052 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-464.1161237 -5.05255153e-19 -1.064772188e-12) (1143 274.3200073 193.9735322)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-3.79177398008e-17 -5.85917462408e-14 4.36207997116e-14) OK.
Max cell openness = 2.92805429189e-16 OK.
Max aspect ratio = 11.1240642867 OK.
Minumum face area = 0.330563016672. Maximum face area = 36.1242486469. Face area magnitudes OK.
Min volume = 1.56100489244. Max volume = 165.81880705. Total volume = 36706377.576. Cell volumes OK.
Mesh non-orthogonality Max: 48.8035890294 average: 8.6477627171
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.859011733412 OK.
Coupled point location match (average 0) OK.
Mesh OK.
Does anyone have any ideas why it is acting so strangely at the inlet?
Thanks
martyn88 is offline   Reply With Quote
Old   September 24, 2012, 17:50
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
please could you post error message appeared to you when tries to run your case.
Ahmed Khattab is offline   Reply With Quote
Old   September 25, 2012, 11:30
Hugh Ingham
I terminated the run, it did not crash. However, using the flowrateinletvelocity BC at inlet, there was no inflow and it pretty much resulted in the initial non-zero velocity field passing through the outlet, leaving the system as a field of zero velocity.
However using the fixed value velocity the flow did develop early in the nozzle but the density just gradually diverged as the flow seemed blocked and the pressure was really high.
Old   September 26, 2012, 04:01
Olivier
olivierG is on a distinguished road
hello,
more info is needed to help you:
- what are the other BC conditions ? (outlet type, wall, ...)
- which solver do you use ?
- fvscheme / solution ?
regards,
olivier
olivierG is offline   Reply With Quote
Old   September 26, 2012, 11:00
Hugh Ingham
Hi Olivier (and anyone else that is interested),
I am running an LES simulation of a turbulent supersonic free jet using the rhoPimpleFoam solver.
I have put my entire case directory in a dropbox which you can find below:
https://www.dropbox.com/s/k7bcdr0gjo...ulation.tar.gz
Or if you would prefer then please find below my BC files and my fvscheme, fvsolution and control dict files:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "5e-05";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (1 0 0);
boundaryField
INLET
type flowRateInletVelocity;
flowRate table
(0 0.05496)
(0.5 5.496)
(3 5.496)
value uniform (0 0 0);
INLET_COFLOW
flowRate table
(0 0.005496)
(0.5 0.5496)
(3 0.5496)
OUTLET
type pressureInletOutletVelocity;
NOZZLEWALL
type fixedValue;
CYCLIC_1
type cyclicAMI;
FREESTREAM_TOP
type slip;
FREESTREAM_BOTTOM
type slip;
CYCLIC_2
type cyclicAMI;
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "5e-05";
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
INLET
type totalTemperature;
gamma 1.338;
phi phi;
psi psi;
T0 uniform 973;
INLET_COFLOW
gamma 1.4;
phi phi;
psi psi;
T0 uniform 300;
OUTLET
type inletOutletTotalTemperature;
gamma 1.4;
T0 uniform 300;
value uniform 300;
NOZZLEWALL
type fixedValue;//cooled nozzle wall
value uniform 300;
CYCLIC_1
type cyclicAMI;
FREESTREAM_TOP
type zeroGradient;
FREESTREAM_BOTTOM
type zeroGradient;
CYCLIC_2
type cyclicAMI;
FoamFile
version 2.0;
format ascii;
location "5e-05";
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
INLET
type zeroGradient;
INLET_COFLOW
type zeroGradient;
OUTLET
type totalPressure;
rho rho;
psi none;
gamma 1.4;
p0 uniform 101325;
value uniform 101325;
NOZZLEWALL
type zeroGradient;
CYCLIC_1
type cyclicAMI;
FREESTREAM_TOP
type zeroGradient;
FREESTREAM_BOTTOM
type zeroGradient;
CYCLIC_2
type cyclicAMI;
FoamFile
version 2.0;
format ascii;
location "5e-05";
object muSgs;
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 0;
boundaryField
INLET
type calculated;
value uniform 0;
INLET_COFLOW
type calculated;
value uniform 0;
OUTLET
type calculated;
value uniform 0;
NOZZLEWALL
type muSgsUSpaldingWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
CYCLIC_1
type cyclicAMI;
FREESTREAM_TOP
type calculated;
value uniform 0;
FREESTREAM_BOTTOM
type calculated;
value uniform 0;
CYCLIC_2
type cyclicAMI;
FoamFile
version 2.0;
format ascii;
location "5e-05";
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 2e-05;
boundaryField
INLET
type fixedValue;
value uniform 2e-05;
INLET_COFLOW
type inletOutlet;
inletValue uniform 2e-05;
OUTLET
type inletOutlet;
NOZZLEWALL
type compressible::kqRWallFunction;
value uniform 2e-05;//not sure about this
CYCLIC_1
type cyclicAMI;
FREESTREAM_TOP
type zeroGradient;
FREESTREAM_BOTTOM
type zeroGradient;
CYCLIC_2
type cyclicAMI;
FoamFile
version 2.0;
format ascii;
class volTensorField;
location "5e-05";
object B;
internalField uniform (0 0 0 0 0 0 0 0 0);
boundaryField
INLET
type fixedValue;
value uniform (0 0 0 0 0 0 0 0 0);
INLET_COFLOW
type fixedValue;
OUTLET
type inletOutlet;
inletValue uniform (0 0 0 0 0 0 0 0 0);
NOZZLEWALL
type zeroGradient;
CYCLIC_1
type cyclicAMI;
FREESTREAM_TOP
type zeroGradient;
FREESTREAM_BOTTOM
type zeroGradient;
CYCLIC_2
type cyclicAMI;
FoamFile
version 2.0;
format ascii;
location "5e-05";
object alphaSgs;
boundaryField
INLET
type calculated;
value uniform 0;
INLET_COFLOW
type calculated;
value uniform 0;
OUTLET
type calculated;
value uniform 0;
NOZZLEWALL
type alphaSgsWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
CYCLIC_1
type cyclicAMI;
FREESTREAM_TOP
type calculated;
value uniform 0;
FREESTREAM_BOTTOM
type calculated;
value uniform 0;
CYCLIC_2
type cyclicAMI;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default backward;
gradSchemes
default Gauss linear limited 0.333;//Gauss linear
divSchemes
default none;
div(phi,U) Gauss upwind;//Gauss filteredLinear2 0.2 0;
div(phi,h) Gauss upwind;//Gauss filteredLinear2 0.2 0;
div(phi,K) Gauss upwind;//Gauss linear;
div(phi,k) Gauss upwind;//Gauss limitedLinear 1;
div(phi,B) Gauss upwind;//Gauss limitedLinear 1;
div(phi,muTilda) Gauss upwind;//Gauss limitedLinear 1;
div(B) Gauss upwind;//Gauss linear;
div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(muEff,U) Gauss linear limited 0.333;//Gauss linear corrected;
laplacian((rho*(1|A(U))),p) Gauss linear limited 0.333;//Gauss linear corrected;
laplacian(alphaEff,h) Gauss linear limited 0.333;//Gauss linear corrected;
laplacian(DkEff,k) Gauss linear limited 0.333;//Gauss linear corrected;
laplacian(DBEff,B) Gauss linear limited 0.333;//Gauss linear corrected;
laplacian(DmuTildaEff,muTilda) Gauss linear limited 0.333;//Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default limited 0.333;//corrected;
fluxRequired
default no;
p ;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"(p|rho)"
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.01;
"(p|rho)Final"
$p;
relTol 0;
"(U|h|k|nuTilda)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-6;
relTol 0.01;
"(U|h|k|nuTilda)Final"
$U;
relTol 0;
PIMPLE
momentumPredictor yes;
nOuterCorrectors 4;
nCorrectors 1;
nNonOrthogonalCorrectors 1;
rhoMin rhoMin [ 1 -3 0 0 0 ] 0.1;
rhoMax rhoMax [ 1 -3 0 0 0 ] 3;
relaxationFactors
fields
equations
"(U|h|k|epsilon|omega).*" 1;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application rhoPimpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 3;
max_Iter 20;
deltaT 1e-05;
writeControl adjustableRunTime;
writeInterval 0.05;
purgeWrite 0;
writeFormat ascii;
writePrecision 12;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo 0.2;
functions
fieldAverage1
type fieldAverage;
functionObjectLibs ( "libfieldFunctionObjects.so" );
enabled true;
outputControl outputTime;
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
Thank you so much for your response,
Hugh
Old   October 1, 2012, 03:39
Default Help still needed
Hugh Ingham
Does anyone have any ideas on how to fix this?
Any help would be much appreciated
Thanks
Hugh
Old   April 21, 2017, 18:34
M. Amirul
maasyraf3 is on a distinguished road
Originally Posted by martyn88 View Post
Hi Sir, how do we asjust the rho in transport properties?
It seems we can change the kinmatic viscosity but not density.
Can you advise thanks
Sent from my M631Y using CFD Online Forum mobile app
Best Regards,
maasyraf3
maasyraf3 is offline   Reply With Quote
flowrateinletvelocity, inlet, inlet boundary condition
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong jannnesss CFX 5 February 25, 2011 16:24
Looking for inlet patch example reimund OpenFOAM Running, Solving & CFD 5 June 10, 2008 18:25
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
