April 22, 2017, 06:29 |
Problem with mpirun in ssh connection
Rep Power: 10 |
Hey,
I am not sure if cfd-online forums is the correct place to ask this question but here it goes. I try to simulate my case with multiple cores using my faculties remote server, connecting from ssh protocol. When I decompose my case and try to run I get the following error: mpirun -np 4 XiFoam -parallel NVIDIA: no NVIDIA devices found [force:26426] *** Process received signal *** [force:26426] Signal: Bus error (7) [force:26426] Signal code: Non-existant physical address (2) [force:26426] Failing at address: 0x7fbc3ad85780 [force:26427] *** Process received signal *** [force:26427] Signal: Bus error (7) [force:26427] Signal code: Non-existant physical address (2) [force:26427] Failing at address: 0x7f338d01fe50 [force:26428] *** Process received signal *** [force:26428] Signal: Bus error (7) [force:26428] Signal code: Non-existant physical address (2) [force:26428] Failing at address: 0x7fd155806898 [force:26429] *** Process received signal *** [force:26429] Signal: Bus error (7) [force:26429] Signal code: Non-existant physical address (2) [force:26429] Failing at address: 0x7fdcc8c5bd50 [force:26429] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fdcd99e24b0] [force:26429] [ 1] /usr/lib/openmpi/lib/openmpi/mca_btl_vader.so(mca_btl_vader_frag_init+0x8e)[0x7fdccb1e329e] [force:26429] [ 2] /usr/lib/libmpi.so.12(ompi_free_list_grow+0x1a9)[0x7fdcd7544cf9] [force:26429] [ 3] /usr/lib/openmpi/lib/openmpi/mca_btl_vader.so(+0x1ea4)[0x7fdccb1e0ea4] [force:26429] [ 4] /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so(+0x16b3)[0x7fdccb5ec6b3] [force:26429] [ 5] /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_add_procs+0xca)[0x7fdcca2dac1a] [force:26429] [force:26426] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fbc53bd54b0] [force:26426] [ 1] /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so(+0x4c4a)[0x7fbc44cecc4a] [force:26426] [ 2] /usr/lib/libmpi.so.12(ompi_free_list_grow+0x189)[0x7fbc51737cd9] [force:26426] [ 3] /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so(mca_btl_sm_add_procs+0x689)[0x7fbc44cea9c9] [force:26426] [ 4] /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so(+0x16b3)[0x7fbc4572f6b3] [force:26426] [ 5] /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_add_procs+0xca)[0x7fbc4441dc1a] [force:26426] [ 6] /usr/lib/libmpi.so.12(ompi_mpi_init+0x859)[0x7fbc51753109] [force:26426] [ 7] /usr/lib/libmpi.so.12(MPI_Init+0x15d)[0x7fbc5177154d] [force:26426] [ 8] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPc+0x1f)[0x7fbc539964cf] [force:26426] [ 9] [force:26427] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f339de464b0] [force:26427] [ 1] /usr/lib/openmpi/lib/openmpi/mca_btl_vader.so(mca_btl_vader_frag_init+0x8e)[0x7f338f58729e] [force:26427] [ 2] /usr/lib/libmpi.so.12(ompi_free_list_grow+0x1a9)[0x7f339b9a8cf9] [force:26427] [ 3] /usr/lib/openmpi/lib/openmpi/mca_btl_vader.so(+0x1ea4)[0x7f338f584ea4] [force:26427] [ 4] /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so(+0x16b3)[0x7f338f9906b3] [force:26427] [ 5] /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_add_procs+0xca)[0x7f338e67ec1a] [force:26427] [ 6] [force:26428] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fd16ee0d4b0] [force:26428] [ 1] /usr/lib/openmpi/lib/openmpi/mca_allocator_bucket.so(mca_allocator_bucket_alloc _align+0x98)[0x7fd1615c80e8] [force:26428] [ 2] /usr/lib/openmpi/lib/openmpi/mca_mpool_sm.so(mca_mpool_sm_alloc+0x28)[0x7fd160fbce58] [force:26428] [ 3] /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so(mca_btl_sm_add_procs+0x5d4)[0x7fd15ff6b914] [force:26428] [ 4] /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so(+0x16b3)[0x7fd1609b06b3] [force:26428] [ 5] /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so(mca_pml_ob1_add_procs+0xca)[0x7fd15f69ec1a] [force:26428] [ 6] /usr/lib/libmpi.so.12(ompi_mpi_init+0x859)[0x7fd16c98b109] [force:26428] [ 7] /usr/lib/libmpi.so.12(MPI_Init+0x15d)[0x7fd16c9a954d] [force:26428] [ 8] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPc+0x1f)[0x7fd16ebce4cf] [force:26428] [ 9] /usr/lib/libmpi.so.12(ompi_mpi_init+0x859)[0x7f339b9c4109] [force:26427] [ 7] [ 6] /usr/lib/libmpi.so.12(ompi_mpi_init+0x859)[0x7fdcd7560109] [force:26429] [ 7] /usr/lib/libmpi.so.12(MPI_Init+0x15d)[0x7fdcd757e54d] [force:26429] [ 8] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPc+0x1f)[0x7fdcd97a34cf] [force:26429] [ 9] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x47a)[0x7fdcdaad87ca] [force:26429] [10] XiFoam[0x42ddff] [force:26429] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fdcd99cd830] [force:26429] [12] XiFoam[0x43d3b9] [force:26429] *** End of error message *** /usr/lib/libmpi.so.12(MPI_Init+0x15d)[0x7f339b9e254d] [force:26427] [ 8] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPc+0x1f)[0x7f339dc074cf] [force:26427] [ 9] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x47a)[0x7f339ef3c7ca] [force:26427] [10] XiFoam[0x42ddff] [force:26427] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f339de31830] [force:26427] [12] XiFoam[0x43d3b9] [force:26427] *** End of error message *** /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x47a)[0x7fbc54ccb7ca] [force:26426] [10] XiFoam[0x42ddff] [force:26426] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fbc53bc0830] [force:26426] [12] XiFoam[0x43d3b9] [force:26426] *** End of error message *** /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x47a)[0x7fd16ff037ca] [force:26428] [10] XiFoam[0x42ddff] [force:26428] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fd16edf8830] [force:26428] [12] XiFoam[0x43d3b9] [force:26428] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 26426 on node force exited on signal 7 (Bus error). mpirun works smoothly if i use the cores in my notebook but I will be running bigger cases and will need 10+ cores very soon. Any idea or help is much appreciated! Bulut |
OF mpirun and parallel problem | heksel8i | OpenFOAM Running, Solving & CFD | 2 | September 11, 2013 05:33 |
Parallel processing problem with Fluent | Harish | FLUENT | 3 | February 8, 2011 09:49 |
[OpenFOAM] Weird Problem with ParaFoam via SSH | cwang5 | ParaView | 2 | July 19, 2010 09:00 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
