Problem with DynamicMesh: nozzle moving along wall
Old   April 18, 2017, 05:29
Default Problem with DynamicMesh: nozzle moving along wall
ashama is on a distinguished road
Good morning everyone
I have a problem with dynamic mesh I hope some one can help me figure it out
I created a geometry of a nozzle filling water into some rectangular space using SALOME, two volumes (nozzle, box) > Partition > create groups > Meshing > create group on geometry, and they are connected with a surface called (internalFace)
I run the case in interFoam and it is OK
I try to make the nozzle move in the Y direction while dumping the water in the volume and the code crashes at specific time. What happen is that the cells in both volumes stay connected while the nozzle is moving, so they get to a very high aspect ratio and Co number jumps very high.
I think I miss one more file other than the dynamicMeshDict - this is the only file I used to move the nozzle and using interDyMFoam.
Nozzle-1.tar.gz
This is the main folder of my simulation and also a screen shot of the mesh at a slice showing the nozzle (Top) and the space (bottom)
Can someone please figure out what I am missing?
Do I miss a file called pointMotionU?
    version     2.0;
    format      ascii;
    class       pointScalarField;
    object      pointMotionU;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    Inlet
        type            uniformFixedValue;
        uniformValue    constant 5;
    Shell
        uniformValue    constant 0;
    Nozzle-Shell
    Top
    Bottom
    InternalFace
Last edited by wyldckat; April 25, 2017 at 07:41. Reason: Added [CODE][/CODE] markers
ashama is offline   Reply With Quote
Old   April 23, 2017, 18:09
Default Looking for a tutorial on Inkjet printing
Hi everyone
Can someone please give me a tutorial on Inkjet printing? If not available, can I get a help in this problem?
I am modeling the geometry in the pictures. Simply, and inlet nozzle into some domain, fixed inlet flow rate and the nozzle has a linear motion during the simulation. I am using interDyMFoam, dynamic mesh. Now, I created the geometry in salome, made a COMPOUND of the cylinder and the box. There is an interface inbetween, called InternalFace. I try to create a baffle for this interface, AIM, and use the dynamicMeshDict to move the nozzle zone. simulation always crash and I cannt figure out the mistake.
I attached the relevant files, 0/U o/alpha.water dynamicMeshDict system-folder
Regards
File Type: png Screenshot from 2017-04-23 23-12-29.png (26.3 KB, 24 views)
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
moving wall problem moloykb FLUENT 0 August 24, 2012 04:27
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
