When can we decide a flow is unsteady or periodic? and How?
Hi All,
I am running fluid(water) flow through a square channel at different Re. For small values of Re, I can observe that the streamlines are not changing with time (after certain duration of simulation) and I conclude that the flow has reached steady state. [Is it correct?] But, for higher values of Re, the streamlines are varying with time even after certain duration of simulation run. For how long should I run the simulation, at higher Re, to verify if the flow reaches steady state or if it remains unsteady? Or is there a way to decide that the flow will be in unsteady state or periodic (after certain Re). The mesh contains nearly 5 million cells. Regards, vidyadhar |
First, this depends on your solver. If you use simple (which is a steady solver) you get a steady flow sometime. This requires that the physical reality of this Re is steady. If you try simple at high unsteady flows the solver may crash. In a pipe flow you get eddies which evolves form the boundary an then move in the free stream. This is unsteady by nature. If you use a correct (unsteady) solver like piso or pimple you don't get a steady solution, which is physical correct. I recommend to follow the course of a suitable flow variable and wait until it's frequency comes more or less to a steady value. You may try the pressure at the outlet for this or forces at the wall. |
Thank you Pilz for the reply.
I am using a transient solver. If the flow becomes unsteady at higher Re, you are asking me to monitor the frequency of a flow variable. But, in my case, the pressure at outlet is equal to ambient and fixed. Can I try to plot the frequency of the flow velocity. I do not know how to plot the forces at the wall. Thank you. |
Put in system/controlDict Code:
functions |
