Error: bad compression specifier 'off', using 'uncompressed' |
October 21, 2015, 01:30 |
ASHISH
Rep Power: 11 |
Hi
I am using foam extended version 3.1 When I try to run any command like blockMesh, snappyHexMesh it gives following error --> FOAM Warning : From function IOstream::compressionEnum(const word&) in file db/IOstreams/IOstreams/IOstream.C at line 74 bad compression specifier 'off', using 'uncompressed' Create mesh for time = 0 Plz Help I am not getting which type of error is this Thank You |
October 31, 2015, 10:07 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
June 8, 2020, 05:33 |
Lukas Fischer
Rep Power: 7 |
FYI:
OpenFOAM 4.1 and 6 (etc.) use Code:
writeCompression uncompressed; Code:
writeCompression off; |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 05:38 |
[ANSYS Meshing] Meshing 2D axisymetric for dynamic compression | sanjeetlimbu | ANSYS Meshing & Geometry | 9 | April 21, 2015 15:41 |
Binary gives significant performance advantage (Mesh & Solve) | glypo | OpenFOAM | 18 | January 1, 2015 13:41 |
Piston gas compression | cob | CFX | 3 | August 27, 2014 03:12 |
Modelling the heat transfer during compression and cooling of natural gas | pano | Main CFD Forum | 0 | December 10, 2010 15:53 |
