DNS of fluid flow with turbulenceProperties as laminar? |
April 28, 2017, 02:52 |
vidyadhar
Rep Power: 9 |
I want to run DNS of fluid flow through a channel. A tutorial is available for LES. I am changing the simulation Model in turbulence properties from LESModel to laminar and run the case. Does it become DNS? (Is this correct? OR Does it mean that I am forcing laminar model to be used?) If it is correct, can I use the same laminar model for running simulations at lower and higher Re? and can I call this as DNS!! Thanks in advance!! vidyadhar |
April 28, 2017, 04:29 |
Uwe Pilz
Rep Power: 15 |
"Models" try approximate the turbulence which the core simulation (with it's spatial and temporal resolution) not covers. Laminar is not a model in close sence and does not introduce additional effects: Which is needed for DNS.
To call it DNS you have to use a very high temporal and spatial resolution, down to the Kolmogorov scale.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
April 28, 2017, 05:30 |
vidyadhar
Rep Power: 9 |
Thank you Pilz for the quick responses!
Why can i use a laminar solver for a turbulent flow? [Heat transfer problem] | blackbow | CFX | 1 | November 22, 2016 04:42 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
