April 28, 2017, 10:03 |
Gamma-Re Theta Spalart Allmaras
Valerio D'Alessandro
Dear Foamers,
we are happy to share with OpenFOAM community our OF implementation of Gamma-Re Theta transition approach based on Spalart--Allmaras turbulence model. We have just a published a paper containing a complete model characterization and several results obtained on airfoils and zero pressure gradient flat plate. The paper preprint is available at: http://www.sciencedirect.com/science...60544217307016. The model and a test case can be download on our gitHub link. https://github.com/vdalessa/gammaReThetatSA Hope this can help your work and research. Valerio |
August 14, 2018, 15:31 |
Pablo Caron
Rep Power: 16 |
Hi Valerio,
I would like to test your library in the NREL S822 airfoil. Currently I am using openfoam 4.0 and I can't compile the version in the repository. Have you managed to compile the library in a version different that 2.x? Thank you in advance. Pablo |
Spalart Allmaras Gamma Re Theta Model | taxalian | SU2 | 4 | December 14, 2020 04:45 |
Gamma Theta Model Error | dl467 | CFX | 4 | November 26, 2015 07:52 |
CFX Spalart Allmaras turbulence models | aweizazuji | CFX | 9 | September 24, 2013 10:53 |
Why RNGkepsilon model gives floating error | shipman | OpenFOAM Running, Solving & CFD | 3 | September 7, 2013 08:00 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
