[Sponsors] | |||||
The same grid, but different calculated y plus values |
Yuehan
Rep Power: 15 ![]() |
Hi Foamers,
I use the same grid with k-epsilon models (standard, realizable and RNG) and k-omega SST model respectively. The calculated y+ by the yPlus function object is so different for different turbulence models. For one patch, the calculated y+ for k-epsilon models is around average 0.7. But for k-omega SST model, it is around 0.07. I understand that there should be some differences. However, 10 times is, I think, too big. Anyone has clue why this happens? Thank you. |
Arvind Jay
Rep Power: 16 ![]() |
Correct computation of y+ involves, correct computation of wall shear stress. Each turbulence model is apt for a certain type of flow and their prediction of flow patterns like flow separation zones may not be correct. Check your wall shear stress values.
Cheers, -J |
#3 | |
Yuehan
It seems that if I change the wall functions for mut from 'mutkWallFunctions' to 'mutUWallFunctions', the calculated y+ of k-omega model increases from 0.07 to 0.3. I also asked another question, regarding the wall functions, y+ and the grid. I appreciate you could also make some comment. What is the consequence of using a high-Re turbulence model on a low-Re grid |
Vignesh Rajendiran
Rep Power: 11 ![]() |
Interesting behaviour. What was the value when you tried calculating the y+ value yourself with the velocity. To which turbulence model y+ value does it match?
Vicky |
Uwe Pilz
The y+ value differs at the surface. Which one do you mention? If you choose some extrem value such large differences may be possible, because the numerical treatment of extrem points is difficult.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
#6 | |
Yuehan
Thank you for your reply. I am using buoyantSimpleFoam to solve the heat transfer problem. The geometry is an ordinary room with a constant temperature cylinder-like heat source inside. The free stream velocity is 0.3 m/s. The heat source and the wall have the convective heat transfer with the air. The first layer thickness of the heat source is 0.5 mm. However, as different models calculate different y+, I don't know whether I should increase or decrease the first layer thickness. Thank you. /Yuehan |
Yuehan
I mean the average yPlus of different surfaces. The average y+ is given by the yPlusRAS function object of OpenFOAM.
Yuehan
I think it is the wall function for mut that matters. When using k-omega SST model on a low-Re grid, the mutkWallFunction tends to give a very low y+ value, while the mutUSpaldingWallFunction or mutLowReWallFunction give the correct value of y+.
#9 |
Vignesh Rajendiran
I think, that depending on the wall function, the local fluid velocity will change and hence the y+ would also vary along with that. So first, you have to decide on the turbulence model for your problem and then choose that particular y+ value.
Thanks Vicky |
#10 | |
Yuehan
Thank you for your reply. I am using k-omega SST model. I believe that y+ is a physical property which in principle should not depend on the wall function or turbulence model chosen. The way that "mutkWallFunction" calculates y+ relies on the assumptions that hold only in the log-law (or overlapped, correct me if I am wrong) region. So if I use a low-Re gird, then there is a risk that "mutkWallFunction" may not be able to give correct y+ values. |
#11 |
SunTime
Rep Power: 6 ![]() |
haha, after five years, I meet the same question as you, the reason for so low yPlus calculated by SST model is exactly by nutwallFunction(low-Re model should choose nutLowRewallfunction)
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Control function in Poisson eqtion grid generation? | dinhanh | Main CFD Forum | 0 | January 8, 2017 02:53 |
| UDF gives different values than calculated manually | RebeccaKn92 | Fluent UDF and Scheme Programming | 4 | February 6, 2016 12:29 |
| Eulerian Wall Film Model - how to use calculated values in UDF? | marie | Fluent Multiphase | 0 | June 24, 2015 09:33 |
| how to export calculated values to a file | colin | Fidelity CFD | 1 | June 5, 2007 05:14 |
| Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 06:59 |
