Problem with finite area method in parallel (foam-extend-4.0)
Hi all,
I would like to run finite area solvers in parallel.
I copied both liquidFilmFoam and surfactantFoam tutorials, adding in the system folder the decomposeParDict from incompressible/simpleFoam/pitzDaily tutorial.
After blockMesh and makeFaMesh, I've decompose the case using decomposePar without a hitch.
Finally, I've tried to run the case in parallel typing "runParallel surfactantFoam 4 &", getting this error:
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: http://www.foam-extend.org |
| \\/ M anipulation | For copyright notice see file Copyright |
Build : 4.0-4fad65ce7cac
Exec : surfactantFoam -parallel
Date : May 02 2017
Time : 13:03:33
Host : ManDybHig_clust
PID : 5971
CtrlDict : "/stoc/andrea/OpenFOAM_EXT/andrea-4.0/tutorial/FAM/planTransport/system/controlDict"
Case : /stoc/andrea/OpenFOAM_EXT/andrea-4.0/tutorial/FAM/planTransport
nProcs : 4
Slaves :
3
ManDybHig_clust.5972
ManDybHig_clust.5973
ManDybHig_clust.5974
Pstream initialized with:
nProcsSimpleSum : 0
commsType : nonBlocking
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] otherProcNo:2 : illegal communicator -1650115904
Communicator should be within range 0..0
[0]
[0] From function PstreamGlobals::checkCommunicator(const label, const label)
[0] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72.
[0]
FOAM parallel run aborting
[0]
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] otherProcNo:0 : illegal communicator -1104586048
[1]
[1] From function PstreamGlobals::checkCommunicator(const label, const label)
[1] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72.
[1]
[1]
[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] otherProcNo:0 : illegal communicator -886773056
[2]
[2] From function PstreamGlobals::checkCommunicator(const label, const label)
[2] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72.
[2]
[2]
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] otherProcNo:2 : illegal communicator 1469405888
[3]
[3] From function PstreamGlobals::checkCommunicator(const label, const label)
[3] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72.
[3]
[3]
MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
I get the same error with all the finite-area-method tutorials. I haven't found any suggestion for this.
Is the above procedure correct?
I'm not able to figure out where this error came from :confused:.
Thanks,
Andrea
