Collecting turbulent statistics with openFOAM |
May 4, 2017, 07:37 |
Manu Chakkingal
Rep Power: 10 |
Hello All
I have a geometry with: Spheres packed in a solid box. Flow of fluid through the pore space. The flow is induced by buoyancy effects. There exists a heat transfer between the fluid and the solid spheres. Its a conjugate heat transfer problem. I would like to collect turbulent statistics of 1st order and higher like : 1. Kinetic energy 2.Reynolds stress 3.turbulent heat flux (u'T') 4.temperature variance (T'T') 5.gradient of the above quantities etc. along a 2d slice in my 3d domain during runtime. (I am only aware of fieldAverage where I could save the whole field) Is it possible using function objects to save the data along the plane. Also should i create new fields like grad(uT) in createfields.H for both solid and fluid to obtain them using any function (what I am looking for) to save data over a plane.
Regards Manu |
March 28, 2018, 13:44 |
HK
Rep Power: 10 |
Hi Manu
There is a post processing utility called cuttingPlane to extract the data (U, p etc) of selected slice/plane in a three dimensional geometry during the simulation. I think there should be an option to write turbulent statistics as well. Please go through the following examples in the tutorials, you may get some idea 1. simpleFoam/motorBike 2. pisoFoam/les/motorBike/ 3. pimpleDyMFoam/movingCone |
March 29, 2018, 03:37 |
Rep Power: 20 |
Depending on your mesh there are several options. The best solution would be a faceZone. This however requires your mesh to match the plane you are trying to evaluate. What you are looking for is the surfaceFieldValue function object.
(Github Link). This can be used with a patch | faceZone | or a sampledSurface. The sampledSurface could e.g be provided via an stl file. The result can be saved to a vtk file for postProcessing in paraview. You should be able to calculate some of those via function objects as well. |
modeling a turbulent flow over an obstacle using OpenFOAM | Daniel_Khazaei | OpenFOAM Running, Solving & CFD | 2 | June 4, 2020 05:21 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
Verification of Turbulent Pipe Flow in OpenFOAM - kwSST | ajcav2 | OpenFOAM Running, Solving & CFD | 6 | April 28, 2017 15:51 |
STATEMENT about how to implement new turbulent models in OpenFOAM | PeterShi | OpenFOAM Running, Solving & CFD | 0 | February 28, 2017 07:18 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 19:20 |
