error when running movingConeTopoFvMesh in parallel
Hello everyone, I'm modeling a rigid body moving through a tube. I modified the movingConeTopoFvMesh.
By using a single processor, the code works well. But once I run the it in parallel, I met the following error: [28] --> FOAM FATAL ERROR: [28] in patch:procBoundary28to19 : Local size of patch is 4 (faces). Received from neighbour 3 faceCentres! [28] [28] From function virtual bool Foam::processorPolyPatch::order(Foam::PstreamBuffe rs&, const primitivePatch&, Foam::labelList&, Foam::labelList&) const [28] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 922. [28] FOAM parallel run aborting Anyone knows how to solve this problem? Should I update the procBoundaries in each step? How should I do it? Thank you so much. |
