July 9, 2013, 03:07 |
Defining mesh motion diffusivity from file
Rep Power: 13 |
Hi Everyone,
I am looking for a sample case where the mesh motion diffusivity (using laplaceFaceDecomposition) is defined from file for each point in the mesh? You may think my case as a shoebox where the top stands still and bottom moves. My mesh is finer at the bottom. Short side walls of this box are my inlet and outlet boundaries and the long side walls are the slip boundaries. Thanks for the replies Best |
July 9, 2013, 04:14 |
Anton Kidess
Rep Power: 29 |
I don't know a tutorial case, but from what I can tell (looking at the code in 1.6-ext) the diffusivity is defined as a surfaceScalarField, i.e. per face. I'm not sure if there is a tool to set values on a surfaceScalarField (such as setFields for vol*Fields), but if there isn't it wouldn't be too hard to write a small tool specifically for your case.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
February 12, 2015, 05:00 |
Christoph Gradl
Rep Power: 12 |
I am also looking for a sample case - did you found one? Do you have another solution or workaround? Thank you, Chrisotph |
October 24, 2023, 08:09 |
M. Montero
Rep Power: 17 |
Hi. I hope someone could update this topic. How generate that file?
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
