June 25, 2017, 02:46 |
Openfoam combustion simulation error
Mankaran Dhiman
Rep Power: 8 |
Hello Everyone
I am trying to simulate a combustion process in a combustor using openfoam v1612+ gui simflow and when I run the solver, following error occurs a number of times during solving: FOAM Warning : From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::sc alar) const [with EquationOfState = Foam:erfectGas<Foam::specie>; Foam::scalar = double] in file /opt/OpenFOAM/OpenFOAM-v1612+/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 105 Can anyone please help me in solving this issue? By the way I selected reacting foam solver (Transient and compressible) and k E turbulence model. Mankaran Dhiman |
June 25, 2017, 06:10 |
Uwe Pilz
Rep Power: 15 |
FOAM Warning : From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::scalar) const [with EquationOfState = Foam::perfectGas<Foam::specie>; Foam::scalar = double] in file /opt/OpenFOAM/OpenFOAM-v1612+/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 105 I think the text of the warning itself is missing, only the source is given.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
June 27, 2017, 03:27 |
Simulation error
Mankaran Dhiman
Rep Power: 8 |
These errors occur as well and then the simulation stops
FOAM FATAL IO ERROR: --> FOAM FATAL IO ERROR: [1] [0] wrong token type - expected Scalar, found on line 0 the word 'nan' wrong token type - expected Scalar, found on line 0 the word 'nan' [1] [0] [1] [0] file: file: C:/Users/manka/simflow/BALE COMBUSTOR/BALE COMBUSTOR/processor1/system/data.solverPerformance.p C:/Users/manka/simflow/BALE COMBUSTOR/BALE COMBUSTOR/processor0/system/data.solverPerformance.p at line at line 0 0 . . [1] [0] [1] [0] --> FOAM Warning : From function --> FOAM Warning : From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) [1] [0] in file in file lnInclude/Scalar.C lnInclude/Scalar.C at line at line 107 107 . . [1] [0] FOAM parallel run exiting FOAM parallel run exiting [1] [0] job aborted: [ranks] message [0] application aborted aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 0 [1] application aborted aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 1 ---- error analysis ----- [0-1] on MankaranPC reactingFoam aborted the job. abort code 1 ---- error analysis ----- |
combustion, combustion chamber, error, openfoam, solver error |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
