Non-Newtonian flow in porous media
Old   June 19, 2017, 11:33
Default Non-Newtonian flow in porous media
Lubna
Lubna is on a distinguished road
Hi
I am writing my master thesis about simulation of non-Newtonian fluid flow in porous media,I am using openFoam
-The model for non-Newtonian fluid is Herschel-Bulkley
-The geometry consists of 28 uniform spheres,and the computational domain is the space between the sphere.In the touching areas between the spheres i made spheres to reduce the touching area to avoid non convergence due to not enough elements, cause it is very small areas
- The mesh is generated in ICEM
the boundary conditions are: fixed velocity at the inlet and fixed pressure at the outlet.
- It is a steady state and the solver is simpleFoam.
- The schemes are uploaded and I have used them before for another geometry obtained from micro-ct scanner and it was converging.
First I was the running the simulation for around one million elements and the residual for vx for example was stuck around the value 0.03, then after refining the mesh to have around 10 million elements the residual was stuck around 0.006. I tried to refine it more but the residual was stuck again at the same point knowing that I am running it for water not even for non-Newtonian fluid yet.
I uploaded the case that I am running now (but i couldnt upload the mesh cause it is very big file), hoping that someone might have an idea of what is missing.
Any hint would be super useful.
Thank you
File Type: zip transportProperties.zip (440 Bytes, 1 views)
Lubna is offline   Reply With Quote
Problem on boundary conditions (multi-phase, porous media, 3 flow domains) Juun FLUENT 1 November 19, 2023 02:06
How to Model Natural Convection Flow in Porous Media at openFOAM? AmirBaqa1987 OpenFOAM 0 December 27, 2016 02:23
Flow through non-equilibrium porous media Jul_Z FLUENT 0 June 24, 2016 08:58
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
Flow through porous media: permeability issue butterfly1 CFX 3 December 23, 2013 22:23
