Starting compressible flow simulation
Hi. I usually simulate incompressible case so friendly with incompressible solvers.
but this time I have to simulate compressible flow (air injection to a tank filled with water). before starting the complex main problem, I want to simulate easier case such as air injection to the empty tank without outlet flow(air just inject to sealed tank until the inlet pressure reaches 250 atm). which solver should i use for the case? is there any similar tutorial? |
