June 24, 2017, 01:11 |
courant no increases rapidly
Bimalendu Mahapatra
Rep Power: 8 |
i am solving a flow over cylinder problem with fine mesh using pimplefoam.
the courant no increases rapidly after each time iteration and the simulation stops. how to fix this problem. |
June 24, 2017, 01:56 |
Uwe Pilz
Rep Power: 15 |
You have to lower the time step or use the Co control.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
June 24, 2017, 07:12 |
Bimalendu Mahapatra
Rep Power: 8 |
sir, thanks for the suggestion.
but we are using pimplefoam over icofoam so that we can give large time steps. |
June 25, 2017, 06:07 |
#4 | |
Uwe Pilz
Rep Power: 15 |
set in controlDict Code:
maxCo 0.1;
June 27, 2017, 04:26 |
Tobias Holzmann
Rep Power: 51 |
Hi all,
Good luck. By the way, depending on the problem, you are not able to increase the Courant number as much as you want.
Keep foaming, Tobias Holzmann |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
Courant Number Increases Rapidly | najunaju | OpenFOAM | 1 | April 2, 2013 05:47 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
