Problem with mass flux calculation in libsimpleFunctionObjects.so
i want to check the mass balance for multiphase cases while running the solver multiphaseEulerFoam. Ideally i want to create an output that calculates the mass balance for all phases e.g. for water and a secondary air phase. So far the closest i got to that is using Code:
Also, is there a possibilty to check the overall mass balance with a function object or do i need to calcualte it by hand for each time step? Thanks!! |
Ok, i found that phi in incompressible solvers is m^3/s and so i guess, to get the mass flux i have to calculate by hand with average alpha on outlet face and the density of the phase.
