pimpleDYMFoam doesn't work in parallel
I work on a case in pimpleDyMFoam, when I run the tutorial in series it works but it doesn't work when it's running in parallel and I receive this fatal error: Code:
An MPI process has executed an operation involving a call to the Thanks in advance |
MPi problem
1. your openmpi is not correctly insatalled. in that case you first make sure other parallel in built tutorials are running, eg interdymfoam tutorials, interphasechangedymfoam tutorials , pimpledymfoam foam tutorials if all these 3 tutorials are runing correctly then it means mpi is runnning and properly installed , it also means you have not setup your problem correctly 2 if tutorials fail to run, then openmpi is not properly installed. so go in third party folder and run allwmake again, or u just run allwmake or makeopnmpi script whatever is there to reinstall openmpi again. thanks |
