July 22, 2017, 15:28 |
Mapping velocity data to a boundary
cyln
Rep Power: 9 |
I would like to map an experimental data (velocity) to my inlet boundary. The experimental velocity data is not uniform within the boundary. I have checked user guide, it explains how to map computational data from a time step, using mapFields command. In my case, I have the velocity data in an external file (i.e. csv). Can someone give me any recommendation on this? I couldnt find any tutorial/documentation about it. Cheers |
July 22, 2017, 16:13 |
Oskar
Rep Power: 10 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
