October 3, 2017, 17:16 |
problem with forwardStep tutorial
Носов Геннадий А
Hello. I had a problem with the forwardStep example. it is normally considered with the original data, but if I specify T = 300 p = 101000 and v = 600 it gives an error that T <0 in the calculation process. How to avoid this?
--> FOAM FATAL ERROR: Negative initial temperature T0: -1625.03 From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam:erfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam:er fectGas<Foam::specie> >, Foam::sensibleInternalEnergy>] in file /opt/CFDSupportFOAM4.0/beta/OpenFOAM-dev/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 54. FOAM aborting Last edited by Gena; October 3, 2017 at 18:24. |
cavity tutorial problem in OF 3.0.x | mohsen.boojari | OpenFOAM Running, Solving & CFD | 5 | February 14, 2016 11:03 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
newbie problem with cavity tutorial | miki | OpenFOAM Running, Solving & CFD | 8 | September 2, 2012 15:22 |
Problem with the Fan tutorial | widedMed | OpenFOAM | 3 | March 29, 2011 04:35 |
Help! Compiled UDF problem 4 Wave tank tutorial | Shane | FLUENT | 1 | September 3, 2010 02:32 |
