Setting Location dependent boundary condition
Old   August 2, 2017, 12:05
Post Setting Location dependent boundary condition
QuantumDart is on a distinguished road
Hello all,
I need to set location Dependant boundary condition.
In a simplified case:
flow through a square pipe is being simulated.
The lower wall of the square pipe is heated(T=400k) starting from 1/4th of the length from the beginning and before its adiabatic.
how do I realize this(or similar) boundary condition???
Thanks!
QuantumDart is offline   Reply With Quote
Old   August 2, 2017, 17:15
Sugajen
Sugajen is on a distinguished road
Quick answer is to make two different patches for the adiabatic and T=400K. There maybe better ways as well.
best,
Sugajen
Sugajen is offline   Reply With Quote
Old   August 5, 2017, 04:21
I tried to do that. The problem is that I am not able to split the patches in starccm+ where i am doing my meshing.
If there is a way to do that would be good to know as well otherwise is there any way to do this independently in OpenFOAM as it would be the easiest for me.
Thanks
Old   August 5, 2017, 04:42
sheaker's Avatar
Oskar
sheaker is on a distinguished road
I have not enough time to check for sure if this is what You are looking for but maybe You could check.
patch splitting for different boundary conditions
sheaker is offline   Reply With Quote
Old   August 5, 2017, 05:11
As i understand its only useful for people using blockMesh so i would not be able to do it as i export my mesh from starccm+ Thanks for your input tho
Old   August 5, 2017, 05:22
sheaker's Avatar
Oskar
Ok. When You convert Your mesh to openFoam format use two tools:
faceSet and boxToFace like in the example below:
echo "faceSet detachFacesIntake new boxToFace (-0.035 -0.01 0) (-0.015 0.01 0)" > detachFacesIntake.setSet
runApplication setSet -batch detachFacesIntake.setSet -latestTime
mv log.setSet log.setSetIntake
rm -f detachFacesIntake.setSet
echo "faceSet detachFacesExhaust new boxToFace (0.015 -0.01 0) (0.035 0.01 0)" > detachFacesExhaust.setSet
runApplication setSet -batch detachFacesExhaust.setSet -latestTime
mv log.setSet log.setSetExhaust
rm -f detachFacesExhaust.setSet
rm -f $meshDir/sets/*_old*
Old   August 5, 2017, 06:26
I don't get how do the tools work and how to implement them.
also upon googling i found that the faceSet tool has been discontinued. does the code remain the same ?
I am new to openFOAM so sorry for the dumb question. :P
ps:I am using ccm26Tofoam for the converting.
Old   August 5, 2017, 16:12
sheaker's Avatar
Oskar
I was using this script in sonicTurbDymEngineFoam for openFoam ext 1.6.
You need to create bash script with similar code and run it in terminal.
First line save faces with its centers inside the box of boxToFace to detachFacesIntake.setSet file with detachFacesIntake 'name'.
Second line creates boundary named detachFacesIntake based on Your detachFacesIntake.setSet file.
I think that You should be able to use it in Your version of openFoam but I'm not 100% sure about setSet .
boundary conditions, openfoam 2.4.x
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Boundary condition setting for non-premixed combustion using reactingFoam skyopener OpenFOAM 0 May 23, 2010 22:55
