Field values at the boundary cells
I want to get values of turbulent kinetic energy at the cells of one of the boundary along with its x and y coordinates. I will use these values to modify one of the terms of the realizableKE model.
My approach is to run loop along the patch to get these values before the kEqn. Which function should I use to get TKE values at the boundary. I have defined the boundary as zeroGradient. |
check this out!
Hi Vedamt,
You are right about running a loop along boundary and patch to get values. I am not aware of the turbulent kinetic energy field variable, but assuming it is TKE, the general method is something like this Code:
forAll (mesh.boundaryMesh(), patchI) Sugajen |
Reading user labels
Thanks for your response. Very much what I required. One more question that I would need patchI if need to loop over a particular patch. But I want to read the patch value from the user defined files such as CoeffDict. I have added Code:
inletID cannot convert 'Foam::dimensioned<int>' to 'Foam::label {aka int}' in initialization Can you correct me on this? |
Sorry, haven't used CoeffDict before.
Similar question
Dear Sugajen,
When using the code below Code:
tmp<volScalarField> FST(k_); I get the following error: no match for 'operator []' in 'FST[cellI]'. I tried several things but unable to resolve. |
