[Sponsors] | |||||
MultiphaseEulerFoam new dragforce compile issue. |
Jack
Rep Power: 0 ![]() |
Hello. I am using openfoam-3.0.x for simulating bubble column (Air/water) with MultiphaseEulerFoam.
Now, I am trying to compile new dragforce model (IshiiZuber) which one is not included in MultiphaseEulerFoam only included in TwophaseEulerFoam but, solver system is totally different. My case, I copied ShiillerNaumann files by changing all namespace. And I also copied dragforce/IshillZuber/IshiiZuber.C on file/Make folder. This means that all set for compling. The last thing is running wmake, then I have an error. ---------------------------------------------------------------------------------------- /opt/OpenFOAM/OpenFOAM-3.0.x/wmake/rules/General/transform:8: '/opt/OpenFOAM/OpenFOAM-3.0.x/platforms/cygwin64mingw-w64DPInt32Opt/cygdrive/c/OpenFOAM/16.10/cygwin64/applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam.o' The command failed for target make: *** [/opt/OpenFOAM/OpenFOAM-3.0.x/platforms/cygwin64mingw-w64DPInt32Opt/cygdrive/c/OpenFOAM/16.10/cygwin64/applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam.o] error1 -------------------------------------------------------------------------------------- It would be highly appreciated if anyone can help me to fix this problem. Thank you!
| Tags |
| dragforce |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Dependencies .dep compile issue | klausb | OpenFOAM Programming & Development | 5 | August 8, 2024 06:55 |
| Issue on zeroGradient BC for system rotation | magnushaese | OpenFOAM Running, Solving & CFD | 2 | January 28, 2022 14:43 |
| rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) | kmkb21 | OpenFOAM Running, Solving & CFD | 1 | March 1, 2018 02:07 |
| foamToTecplot360 issue with multiregion solvers | manuc | OpenFOAM Post-Processing | 2 | November 21, 2016 14:51 |
| Convergence issue in natural convection problem | chrisf90 | FLUENT | 5 | March 5, 2016 09:30 |
