September 3, 2020, 10:38 |
cht+interCondensatingEvaporatingFoam
wanghongjie
Rep Power: 5 |
Hi, I am new to OF. I coupled chtMultiRegionFoam with the modified interCondensatingEvaporatingFoam, the solver compiles without problems (just judging from the compiled results), but once the temperature solves, there will be an error. I put up my TEqn.H and 0/T, please help me see where the problem is.
0/BASE/T dimensions [0 0 0 1 0 0 0]; internalField uniform 0; boundaryField { SJUERE { type zeroGradient; } SFRONTANDBACK { type empty; } HEAT { type fixedGradient; gradient uniform 50; } BASE_FLUID { type compressible::turbulentTemperatureCoupledBaffleMix ed; value $internalField; Tnbr T; kappaMethod solidThermo; } } TEqn.H { Info<<"10"<<endl; volScalarField& T = thermo->T(); Info<<"11"<<endl; tmp<volScalarField> tcp(thermo->Cp()); const volScalarField& cp = tcp(); Info<<"12"<<endl; const dimensionedScalar Cp1 = thermo->Cp1(); const dimensionedScalar Cp2 = thermo->Cp2(); Info<<"13"<<endl; rhoCp = rho*cp; Info<<"14"<<endl; kappaEff = thermo->kappa() + rho*cp*turbulence.nut()/Prt; Info<<"15"<<endl; const surfaceScalarField rhoCpPhi ( "rhoCpPhi", rhoPhi*(Cp1 - Cp2) + phi*rho2*Cp2 ); Info<<"16"<<endl; Pair<tmp<volScalarField>> vDotAlphal = mixture.mDot(); Info<<"17"<<endl; fvScalarMatrix TEqn ( fvm::ddt(rhoCp, T) + fvm::div(rhoCpPhi, T) - fvm::Sp(fvc::ddt(rhoCp) + fvc::div(rhoCpPhi), T) - fvm::laplacian(kappaEff, T) + mixture.TSource() ); Info<<"18"<<endl; TEqn.relax(); TEqn.solve(mesh.solver(he.select(finalIter))); thermo->correct(); Info<< "min/max(T) = " << min(T).value() << ", " << max(T).value() <<endl; } Error: #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::mapDistributeBase::mapDistributeBase(Foam::U List<int> const&, Foam::UList<int> const&) at ??:? #4 Foam::mapDistribute::mapDistribute(Foam::UList<int > const&, Foam::UList<int> const&) at ??:? #5 Foam::mappedPatchBase::calcMapping() const at ??:? #6 Foam::mappedPatchBase::map() const at ??:? #7 void Foam::mappedPatchBase::distribute<double>(Foam::Li st<double>&) const at ??:? #8 Foam::compressible::turbulentTemperatureCoupledBaf fleMixedFvPatchScalarField::updateCoeffs() at ??:? #9 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in ~/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/bin/chtConEvaFoam #10 Foam::temperaturePhaseChangeTwoPhaseMixtures::cons tant::TSource() const at ??:? #11 ? in ~/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/bin/chtConEvaFoam #12 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #13 ? in ~/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/bin/chtConEvaFoam Segmentation fault (core dumped) |
March 22, 2021, 04:54 |
John Kim
Rep Power: 5 |
hello wanghongjie.
I was trying to compile cht foam and interCondensatingEvaporatingfoam together but I failed. Can you give me an advice for it..? If you can give me the solver, it will be a great help. Also I can help you with dealing the error that occurred by revising your solver. Thanks, john |
January 17, 2022, 05:05 |
the Library Twophase Flow might help
Rep Power: 13 |
Display Modes | |
Multi Region CHT Simulation | akarfirath | STAR-CCM+ | 4 | January 24, 2020 15:19 |
Efficiency of centrifugal compressor - Adiabatic walls vs CHT | Burken | CFX | 0 | May 11, 2018 13:53 |
CHT with a moving solid | TCosta | CONVERGE | 5 | August 30, 2016 16:52 |
vof with cht | klilla | OpenFOAM Programming & Development | 2 | July 29, 2015 06:30 |
Expert-param:: Cht diffusion scheme | PCFD | CFX | 4 | July 12, 2010 14:49 |
