Simulate a iron hopper
Like Tree1Likes
  • 1 Post By alberto
Old   January 29, 2007, 13:18
Default Hi, I want to simulate a i
Michael Page
micpage18 is on a distinguished road
I want to simulate a iron hopper.
The hopper is like a silo with a cone shape full of iron ball (2 cm of diameter). The silo is emptied by gravity.
I want to know what is the "flow rate" of iron ball.
Is Openfoam can simulate a case like this?
Thank you
Michael Page
Michael Page
michael.page@simu-k.com
Simu-K inc.
www.simu-k.com
micpage18 is offline   Reply With Quote
Old   January 29, 2007, 18:38
Default Hoppers discharge of fine powd
Alberto Passalacqua
Hoppers discharge of fine powders (up to 1mm; yours are not exactly "particles" :-)) is commonly simulated using a two-fluid model. The properties of the granular phase can be described:
a) using the kinetic theory of granular flow, together with a frictional stress model (see Schaeffer, Johnson and Jackson, Srivastava and Sundaresan), which is essential to properly capture the flow field properties in the densest zones.
This approach was applied in a recent paper from Srivastava A., Sundaresan, S., Analysis of a frictional–kinetic model for gas–particle flow, Powder Technology 129 (2003) 72– 85, using MFIX ( www.mfix.org ).
b) using a specific rheological model.
OpenFOAM currently implements the kinetic theory of granular flow in twoPhaseEulerFoam and some frictional models. Unfortunately the solution of dense flows like those in hoppers is still not fully stable and some more work is necessary (and welcome ;-)).
The same solver implements a simple rheological model (see Gidaspow and others authors, look for "normal stress modulus"), which is more stable.
c) A more computationally expensive method is based on Discrete Element Simulations. But I don't have much experience with it.
For the first two approaches, I've some doubt due to the size of the spheres.
How big is your system?
Regards,
Alberto
BlnPhoenixKA likes this.
Alberto Passalacqua
Old   August 28, 2017, 21:48
Viraj Belekar
virajb is on a distinguished road
Hello Dr. Alberto,
I am trying to simulate a test case almost exactly similar to what Michael tried to do. I am simulating granular flow in a silo with particle diameter 1mm and gravity discharge.
I want to use the Schaeffer and the S&S model separately for this purpose.
I wanted to confirm whether the simulation of such flow is still not fully stable in OpenFOAM?
Thank you!
Best Regards
Viraj
virajb is offline   Reply With Quote
How to simulate a fan? Andy CFX 9 July 14, 2008 10:49
can we simulate y+ sachin FLUENT 1 June 14, 2008 00:52
Wedge Shaped Hopper Arun FLUENT 0 December 31, 2007 06:27
CFD Consultancy-Iron & Steel cfdmetal Main CFD Forum 1 May 3, 2002 08:35
How can i simulate? Sung J.Joong Main CFD Forum 0 August 19, 1999 02:53
