Maximum number of iterations exceeded when calculating T with AMI baffles only |
August 26, 2017, 08:41 |
Bruno Lebon
Rep Power: 13 |
I get the following error when running adaptive meshing with heat transfer only when creating baffles:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : buoyantPimpleRelativeDyMFoam Date : Aug 26 2017 Time : 13:08:54 Host : PID : 71504 Case : run/direct_chill_AMI_baffles nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone rotatingZone Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleInternalEnergy; } AMI: Creating addressing and weights between 96728 source faces and 96728 target faces AMI: Patch source sum(weights) min/max/average = 1, 1.0006151, 1.0000008 AMI: Patch target sum(weights) min/max/average = 1, 1.0006151, 1.0000008 Reading transportProperties Reading casting velocity Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave bounding k, min: 0 max: 0.1 average: 0.1 bounding omega, min: 0 max: 1 average: 1 kOmegaSSTCoeffs { alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.55555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } Reading g Reading hRef Calculating field g.h Reading field p_rgh Creating field dpdt Creating field kinetic energy K No MRF models present Radiation model not active: radiationProperties not found Selecting radiationModel none Creating finite volume options from "constant/fvOptions" Selecting finite volume options model type mushyZoneSource Source: melt1 - selecting all cells - selected 4187281 cell(s) with volume 0.00070747277 PIMPLE: Operating solver in PISO mode Reading/calculating face velocity rhoUf Courant Number mean: 8.9612124e-05 max: 0.00078561122 Starting time loop Courant Number mean: 8.8724876e-05 max: 0.00077783289 deltaT = 1.1764706e-05 Time = 1.176470588e-05 AMI: Creating addressing and weights between 96728 source faces and 96728 target faces AMI: Patch source sum(weights) min/max/average = 0.9999976, 1.0006151, 1.0000007 AMI: Patch target sum(weights) min/max/average = 0.9999976, 1.0006151, 1.0000007 DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 0.0079730276, No Iterations 10 time step continuity errors : sum local = 0.0013459109, global = -0.00080712699, cumulative = -0.00080 712699 Execution time for mesh.update() = 19.84 s diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 - selecting all cells - selected 4187281 cell(s) with volume 0.00070747277 - selecting all cells - selected 4187281 cell(s) with volume 0.00070747277 DILUPBiCG: Solving for Ux, Initial residual = 0.25250652, Final residual = 7.8829779e-09, No Iteratio ns 50 DILUPBiCG: Solving for Uy, Initial residual = 0.29979727, Final residual = 7.9730354e-09, No Iteratio ns 49 DILUPBiCG: Solving for Uz, Initial residual = 0.0012666971, Final residual = 9.3209637e-09, No Iterations 30 - selecting all cells - selected 4187281 cell(s) with volume 0.00070747277 DILUPBiCG: Solving for e, Initial residual = 0.044821635, Final residual = 8.8728646e-09, No Iterations 35 --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleInternalEnergy>] in file /user/mxam/mxstbbl/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib64/libc.so.6" #6 ? at ??:? Aborted Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : moveDynamicMesh -checkAMI Date : Aug 26 2017 Time : 13:16:26 Host : PID : 71534 Case : run/direct_chill_AMI_baffles nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone rotatingZone Writing VTK files with weights of AMI patches. PIMPLE: Operating solver in PISO mode Time = 1e-05 PIMPLE: iteration 1 --> FOAM Warning : From function virtual bool Foam::solidBodyMotionFvMesh::update() in file solidBodyMotionFvMesh/solidBodyMotionFvMesh.C at line 228 Did not find volVectorField U Not updating Uboundary conditions. Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. <<Number of duplicate (not baffle) faces found: 4. This might indicate a problem. <<Number of faces with non-consecutive shared points: 4. This might indicate a problem. Mesh topology OK. Boundary openness (-3.6710028e-16 4.4562628e-16 6.7448791e-17) OK. Max cell openness = 5.9972489e-16 OK. Max aspect ratio = 25.272324 OK. Minimum face area = 2.7957022e-09. Maximum face area = 6.910027e-07. Face area magnitudes OK. Min volume = 4.0550359e-13. Max volume = 3.4550135e-10. Total volume = 0.00070747277. Cell volumes OK. Mesh non-orthogonality Max: 68.822452 average: 7.674973 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.3704271 OK. Mesh geometry OK. Mesh OK. Calculating AMI weights between owner patch: AMI1 and neighbour patch: AMI2 AMI: Creating addressing and weights between 96728 source faces and 96728 target faces AMI: Patch source sum(weights) min/max/average = 0.99999763, 1.0006151, 1.0000007 AMI: Patch target sum(weights) min/max/average = 0.99999763, 1.0006151, 1.0000007 ExecutionTime = 51.69 s ClockTime = 52 s Code:
Starting time loop Courant Number mean: 8.7933632e-05 max: 0.00077478393 deltaT = 1.1764706e-05 Time = 1.1764706e-05 DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 0.0090929751, No Iterations 13 time step continuity errors : sum local = 0.00051673172, global = -3.383239e-08, cumulative = -3.383239e-08 Execution time for mesh.update() = 1.35 s diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 - selecting all cells - selected 3470648 cell(s) with volume 0.00070742718 - selecting all cells - selected 3470648 cell(s) with volume 0.00070742718 DILUPBiCG: Solving for Ux, Initial residual = 0.2182415, Final residual = 6.5444622e-09, No Iterations 37 DILUPBiCG: Solving for Uy, Initial residual = 0.26917409, Final residual = 8.6276434e-09, No Iterations 37 DILUPBiCG: Solving for Uz, Initial residual = 0.034115545, Final residual = 8.0461001e-09, No Iterations 30 - selecting all cells - selected 3470648 cell(s) with volume 0.00070742718 DILUPBiCG: Solving for e, Initial residual = 0.046034907, Final residual = 7.1364143e-09, No Iterations 29 DICPCG: Solving for p_rgh, Initial residual = 0.8427223, Final residual = 0.0082917735, No Iterations 119 - selecting all cells - selected 3470648 cell(s) with volume 0.00070742718 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.4750221e-09, global = -9.8323748e-11, cumulative = -3.3930714e-08 DICPCG: Solving for p_rgh, Initial residual = 0.17367083, Final residual = 9.4662022e-09, No Iterations 443 - selecting all cells - selected 3470648 cell(s) with volume 0.00070742718 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 4.5486516e-15, global = 4.9450138e-18, cumulative = -3.3930714e-08 DILUPBiCG: Solving for omega, Initial residual = 0.089374264, Final residual = 7.5486908e-09, No Iterations 23 DILUPBiCG: Solving for k, Initial residual = 0.99999999, Final residual = 9.4425125e-09, No Iterations 41 ExecutionTime = 27.5 s ClockTime = 28 s Also, I am using rhoConst and hConst, so I did not expect the T calculation from e to diverge. Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleInternalEnergy; } |
August 26, 2017, 17:43 |
Solved by removing cyclicAMI value
Bruno Lebon
Rep Power: 13 |
Weird resolution for this:
I managed to get rid of the error by removing the value key in the cyclicAMI boundary condition for T: Code:
"AMI.*" { type cyclicAMI; } Code:
"AMI.*" { type cyclicAMI; value 0; } |
ami, baffles |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
