rhoCentralFoam tutorial Courant nan
I installed openFoam 4.0 from Debian repository. First, the examples did not run properly. Thus, I downloaded the tutorial from the openFoam site repository for the 4.0 version. At least the incompressible cavity example ran ok. However, when the compressible rhoCentralFoam was tested with shocktube example, it reports inmediatelly: --------- Mean and max Courant Numbers = nan nan deltaT = 1.19904e-06 Time = 1.19904e-06 --------- The program then runs each of the time step with nan on each of the variables. Any idea? |
test with sonicFoam
Hi, perhaps this helps:
The example "prism" within compressible/sonicFoam/ras works fine. Whereas the "shocktube" example within compressible/sonicFoam/laminar result in a similar error that the one reported in rhoCantralFoam: --------------------- Creating turbulence model Selecting turbulence model type laminar Creating field kinetic energy K No MRF models present No finite volume options present Starting time loop Time = 1e-05 Courant Number mean: nan max: nan ---------------------------- |
Fixed!
I did not know that setFields command must be run before typing rhoCentralFoam I suggest that tutorials should have at least a minimalistic README |
Most tutorials have a Allrun script that shows the steps. I think those show the general way to run a particular tutorial. If there is no Allrun script it probably is just blockMesh and then the solver. In OpenFOAM 4.x there is at least a script that shows that setFields is needed for the shocktube tutorial. Not sure if it was missing in OpenFOAM 4.0, but I think it would not need a README in this case. Regards, Tom |
