rhoCentralFoam tutorial Courant nan
Old   August 27, 2017, 12:01
Default rhoCentralFoam tutorial Courant nan
Gustavo Cordoba
gcordobaguerrero is on a distinguished road
I installed openFoam 4.0 from Debian repository.
First, the examples did not run properly. Thus, I downloaded the tutorial from the openFoam site repository for the 4.0 version. At least the incompressible cavity example ran ok.
However, when the compressible rhoCentralFoam was tested with shocktube example, it reports inmediatelly:
Mean and max Courant Numbers = nan nan
deltaT = 1.19904e-06
Time = 1.19904e-06
The program then runs each of the time step with nan on each of the variables.
Any idea?
gcordobaguerrero is offline   Reply With Quote
Old   August 27, 2017, 12:16
Default test with sonicFoam
Gustavo Cordoba
Hi, perhaps this helps:
The example "prism" within compressible/sonicFoam/ras works fine.
Whereas the "shocktube" example within compressible/sonicFoam/laminar result in a similar error that the one reported in rhoCantralFoam:
Creating turbulence model
Selecting turbulence model type laminar
Creating field kinetic energy K
No MRF models present
No finite volume options present
Starting time loop
Time = 1e-05
Courant Number mean: nan max: nan
Old   August 27, 2017, 12:37
Gustavo Cordoba
Fixed!
I did not know that setFields command must be run before typing rhoCentralFoam
I suggest that tutorials should have at least a minimalistic README
Old   August 28, 2017, 05:11
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Most tutorials have a Allrun script that shows the steps. I think those show the general way to run a particular tutorial. If there is no Allrun script it probably is just blockMesh and then the solver.
In OpenFOAM 4.x there is at least a script that shows that setFields is needed for the shocktube tutorial. Not sure if it was missing in OpenFOAM 4.0, but I think it would not need a README in this case.
Regards,
Tom
tomf is offline   Reply With Quote
courant number, nan, rhocentralfoam, tutorial
cyclicACMI gives Courant number nan Drew1 OpenFOAM 0 July 22, 2014 16:46
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) Scabbard OpenFOAM Running, Solving & CFD 1 July 22, 2014 04:50
Why simulation results showing "nan" values? Sargam05 OpenFOAM 4 September 10, 2012 12:37
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 16:01
pls help fluctuating residuals due to courant no sagar CFX 3 March 28, 2006 01:10
