ERROR Floating point exception (core dumped)
hi guys, i start a new thread because in the previous one i've made a mistake in the solver.
the correct error that i encounter is this. it happens both in serial and in parallel running. could you help me? >>>serial running error (entire ): No MRF models present No finite volume options present Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0579352, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0929238, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0542617, No Iterations 2 smoothSolver: Solving for e, Initial residual = 0.000261764, Final residual = 7.74102e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0663316, No Iterations 3 GAMG: Solving for p, Initial residual = 0.0278163, Final residual = 0.00266582, No Iterations 14 time step continuity errors : sum local = 37.3853, global = 2.26347, cumulative = 2.26347 rho max/min : 1.17844 1.12039 smoothSolver: Solving for omega, Initial residual = 0.00222518, Final residual = 4.56574e-05, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.999003, Final residual = 0.00154568, No Iterations 2 bounding k, min: 6.24333e-16 max: 7139.05 average: 1.00464 ExecutionTime = 57.48 s ClockTime = 57 s Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.250381, Final residual = 0.0101435, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.258735, Final residual = 0.00835699, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.244236, Final residual = 0.0126606, No Iterations 4 smoothSolver: Solving for e, Initial residual = 1, Final residual = 0.181467, No Iterations 1 #0 Foam::error: printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::hePsiThermo<Foam:siThermo, Foam: pureMixture<Foam::sutherlandTransport<Foam::specie s::thermo<Foam::hConstThermo<Foam:perfectGas<Foam: :specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? #4 Foam::hePsiThermo<Foam:psiThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam::sp ecies::thermo<Foam::hConstThermo<Foam:perfectGas<F oam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #5 ? in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam" Floating point exception (core dumped) HERE INSTEAD >>PARALLEL RUNNING ERROR (some extranct) [1] [3] #0 Foam::error:printStack(Foam::Ostream&)#0 Foam::error::pprintStack(Foam::Ostream&)[0] #0 Foam::error:printStack(Foam::Ostream&)[2] #0 Foam::error:printStack(Foam::Ostream&) at ??:? [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [3] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #2 ? at ??:? [3] #2 ? at ??:? [0] #2 ? at ??:? [2] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::hePsiThermo<Foam:psiThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam::sp ecies::thermo<Foam: :hConstThermo<Foam:perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >: calculate() in "/lib/x86_64-linux-gnu/libc.so.6" .. .. . .. .. .. .. _11pureMixtureINS_19sutherlandTransportINS_7specie s6thermoINS_12hConstThermoINS_10perfectGasINS_6spe cieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calcul ateEv+0x187)[0x7fd6fdfe4377] [gio-HP-EliteBook-8460p:05818] [ 4] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThe rmoINS_9psiThermoENS_11pureMixtureINS_19sutherland TransportINS_7species6thermoINS_12hConstThermoINS_ 10perfectGasINS_6specieEEEEENS_22sensibleInternalE nergyEEEEEEEE7correctEv+0x2a)[0x7fd6fe00072a] [gio-HP-EliteBook-8460p:05818] [ 5] rhoSimpleFoam(+0x26d1d)[0x559a688cad1d] [gio-HP-EliteBook-8460p:05818] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7fd6f89573f1] [gio-HP-EliteBook-8460p:05818] [ 7] rhoSimpleFoam(+0x2c39a)[0x559a688d039a] [gio-HP-EliteBook-8460p:05818] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 3 with PID 5821 on node gio-HP-EliteBook-8460p exited on signal 8 (Floating point exception). |
how can i solve it?
:confused::confused::confused: |
